Mysterious Miss!!!!!!!!!!!
I am having a problem locating the cause of this miss.
1st Engine Code said Evap Leak
2nd Code Said miss on Cylinder 4
While driving the tach just drops off and then right back up almost like I hit a bump and it goes right back up ,at first it was intermittent, now it is anytime I drive, and the little dip on the tach goes from a little dip to bounce around like a geiger meter.It is not as bad when I keep the revs up or down shift ,but today it was so bad it was jerking the car like if your coming to a stop in to high a gear.
So far I have installed nw plugs and fuel injectors due to it smelling like it was leaning out.
Does anyone have a clue as to what is causing this.
98 Honda Civic EX
Manual w/ a Cold Air Intake
No other Mods
  • 4 months later...
