oneaccord1980 Posted October 22, 2012 Share Posted October 22, 2012 Ok here it goes... I just recently fixed the leaking coolant problem... I drove my accord earlier today and when I sat on the red light for awhile, the radiator fan turned on... of course, to cool the engine from idling heat... but the weird part of it was that it was making weird screeching sound... I turned my ac on and the sound continued... when I finally parked and turned off the car, the fan kicks in like normal but it wasnt normal because of the sound it made... it sounds like a grinding sound or a screeching sound like something is hindering the fan from doing its job... could it be that I need a new radiator fan? please help thank you =) Link to comment Share on other sites More sharing options...
James Matteu Posted October 22, 2012 Share Posted October 22, 2012 Yes, you need a new fan motor. The motor has bearings and the casing is not designed where you can rebuild the motor. My advise, remove the motor first to see what condition the shroud is in. I'm not saying what it looks like on the outside but rather can it put up with having the motor removed; it is possible to damage the shroud in removing the fan motor and its just easier to get replacement motor and shroud at the same time. Link to comment Share on other sites More sharing options...
oneaccord1980 Posted October 22, 2012 Author Share Posted October 22, 2012 bought a whole new radiator fan assembly for 88 bucks... replaced the whole deal and it worked great!!! It feels good to know that the creepy sound is gone... thanks a lot James for your courteous help =) Link to comment Share on other sites More sharing options...
