blue smoke?
ALLMOTOREG6
Depends on what's causing it.
1. Bad stem seals, read your plugs.
2. Bad rings, check compression both dry and wet.
3. Both 1 and 2.
And as far as repair costs, stem seal kits are relatively cheap, ~$40-60, and a rebuild seal kit can run about $300 plus machine shop costs about $300. So, anywhere from $40 to $600, depends on what's wrong. Of course, other than the machine shop, none of this includes labor.
