Cesar Antonio Villalta Posted October 5, 2012 Share Posted October 5, 2012 well, the civic is not mine, it belongs to my sister, and as i understand, the original engine in the car was near its death, so my sister swapped it out. now the rest is the tricky part. As ive read just about everywhere, the proper engine for my car is a (1.6L, 4 CYL, SOHC), VTEC-E (VIN "7" 6TH DIGIT) Automatic Transmission now, the problem is that my sister had the engine swapped for a (1.6L, 4 CYL, SOHC), BASE (VIN "6" 6TH DIGIT). now, the check engine light is on in the car, (im assuming because the computer finds a problem with a nonvtec engine) i bought an ecu for a non vtec motor, but when it is plugged into the car, it locks the transmission in park, and will not allow the car to move. i took my vehicle to honda, and they told me that there wasnt much they could do for me. so i need help, as to best proceed, because i need a car. my intentions were to buy a replacement engine and i have one lined up, but i need to know if there is ANYTHING else i can do, because i do not want to spend that much money. Link to comment Share on other sites More sharing options...
James Matteu Posted October 5, 2012 Share Posted October 5, 2012 Um, is the ECU you installed an Automatic ECU? Is it the right one for that motor and transmission? You can remove the lock-up solenoid until you figure it out. Link to comment Share on other sites More sharing options...
Cesar Antonio Villalta Posted October 6, 2012 Author Share Posted October 6, 2012 it is for an automatic transmission, and its also for a base engine. im new to the whole car mod thing though, so i literally have no clue what im supposed to do. Link to comment Share on other sites More sharing options...
Xeryon Posted October 6, 2012 Share Posted October 6, 2012 Technically there is no such thing as a 'base engine' Lets start by reading the engine code off the front of the engine block and then read off the ecu code and we can check and see if you ended up with the right items. Link to comment Share on other sites More sharing options...
