coilover springs
mendezz45
Where to begin?
The term 'coilover' in the import world usually refers to a fully assembled piece of hardware that you would not take apart. In almost all instances of suspension system failure the spring is not the break point, the shock or strut blows and is generally the failure point. Regardless of the fail point if your vehicle indeed has a coilover set on it and you need service parts you will need to figure out who the manufacturer is to obtain your repair parts. If your car is outfitted with a default spring and shock/strut combo utilizing the factory top hats you can buy springs anywhere. I would just avoid generic eBay as those DO tend to break.
