customcardriver Posted October 1, 2012 Share Posted October 1, 2012 ok i have an 89 honda accord lxi and i am looking to go wicked crazy. i want to know what all motors will bolt to my transmission its the aod for a fi car Link to comment Share on other sites More sharing options...
James Matteu Posted October 1, 2012 Share Posted October 1, 2012 A dual-carb or single carb A20 will, but those wouldn't be worth the trouble and would make it slower. H22 with H22 transmission and all the goodies. You'll be going from a mechanical linkage to cable tranny on hydraulic clutch. Do a search, the swap has been documented in magazines so finding a parts list shouldn't be hard. Link to comment Share on other sites More sharing options...
Xeryon Posted October 1, 2012 Share Posted October 1, 2012 An H23 would be a little easier to find at a fair price and be not quite the same performance but closer in vintage and a little less wiring with only going to an OBD1 system. Link to comment Share on other sites More sharing options...
customcardriver Posted October 3, 2012 Author Share Posted October 3, 2012 i run the aod trans (automatic) don't want to switch to a manual (bad knee) Link to comment Share on other sites More sharing options...
customcardriver Posted October 3, 2012 Author Share Posted October 3, 2012 thank you for the info on the H22 and H23, is that where the limit ends to bolt to this trans? Link to comment Share on other sites More sharing options...
Xeryon Posted October 4, 2012 Share Posted October 4, 2012 Well, I think you're stuck then. There isn't going to be much info on trying to get your auto to properly work with the ecus of the newer h23 and h22. i wouldn't even know where to begin. for the most part auto transmissions need to be mated to similar generation engines for the ecu reason. Link to comment Share on other sites More sharing options...
customcardriver Posted October 12, 2012 Author Share Posted October 12, 2012 ok well thank you all for your input. i guess its time to play and see what i can blow up lol. i'll post up what we design and play with. but will the h22 bolt to the trans i am running? Link to comment Share on other sites More sharing options...
James Matteu Posted October 12, 2012 Share Posted October 12, 2012 Nobody said H22 would bolt up. A20s of varying fuel delivery will only bolt up. H22 H23 etc are are engine and trans swaps. And the H22 can be had with an auto so you don't have to go to 5spd. Link to comment Share on other sites More sharing options...
