lsh99 Posted September 28, 2012 Share Posted September 28, 2012 I have a 99 Accord V6 Automatic that jerks for the first few minutes upon driving it.The Rpms flutter high and low when I give it a little gas and when braking the car jerks to stop.This only happens when the car is cold after its fully warmed it goes away after the first few minutes.So only when the engine is cold not warm??.I do warm up my car and Ive had a transmission flush and tune up about 3 months prior.Any ideas on what it could be? Link to comment Share on other sites More sharing options...
James Matteu Posted September 30, 2012 Share Posted September 30, 2012 Fast Idle Thermo Valve (FITV), make sure you are getting air flowing through it when the motor is cold: Remove the Air Intake Tube Start motor Use finger to cover FITV bypass You should feel a slight vacuum and the engine should stagger or stall when you cover it. If you get no suction and no response, the FITV is not functioning. The Intake Air Control Valve (IACV) has a similar looking hole but keeps sucking air even after the car warms up. Yes, this is a test you do with the car cold. Link to comment Share on other sites More sharing options...
