according to goodburger Posted September 26, 2012 Share Posted September 26, 2012 hi all new to the site i have a 1996 accord that shifts hard even after fluid changes could it be a mount or solenoid? Link to comment Share on other sites More sharing options...
James Matteu Posted September 27, 2012 Share Posted September 27, 2012 Does your Speedometer work? If not, see if the VSS works (try to engage the cruise control while the speedometer is non-functional). If the VSS is good, check the connection between the VSS and the TCU connector (with a multimeter). I'm sure others will chime in, I just wanted to point this out since the Honda TCU relies heavily on the VSS input for its fuzzy-logic calculations to achieve their Gradelogic Shifting, specifically its shifting after cruising speed locks* the mainshaft (*that second "shift" you feel when you've achieved your desired cruising speed and let off the gas). Link to comment Share on other sites More sharing options...
Turtlehead Posted September 28, 2012 Share Posted September 28, 2012 Auto or manual? I assume auto because you mention solenoid but please confirm... Link to comment Share on other sites More sharing options...
