Jerzystylz Posted August 28, 2012 Share Posted August 28, 2012 My 97 accord EX is lowered but I usually dont have any clearance or scraping issues...but there was a portion of highway that was gettin reworked...and I hit a "dip" in the road at about 60MPH....hit it pretty hard... then about 20 minutes later the ABS light comes on. Now whenever I start the car...after about 1 - 3 minutes of driving the ABS light would come back on..... any Ideas on where I should start to look? FYI....never had any ABS light issues ever before with the car....not the first owner thought..but have had it for a few years Link to comment Share on other sites More sharing options...
Turtlehead Posted August 29, 2012 Share Posted August 29, 2012 Yeh! Pull the codes and if you have more then one code start by diagnoising the first code shown first, and always follow the rest procedure and don't forget to write the codes down before doing so. Link to comment Share on other sites More sharing options...
Jerzystylz Posted August 29, 2012 Author Share Posted August 29, 2012 I didn't think the code reader would pull codes for abs light...thought it was just for check engine light....I will plug it in and see what codes I get... thanks! Link to comment Share on other sites More sharing options...
Turtlehead Posted September 1, 2012 Share Posted September 1, 2012 You don't need an HDS scanner to read the codes. Your car should still have a two pin service conntector under the glove compartment that you jumper and turn the key to the on position and then count the flashes on the ABS indicator light. ie. eight long blinks followed by two fast blinks means code 8-2. if there is another code(s) they will follow. Once all the codes have been shown they will repeat. Link to comment Share on other sites More sharing options...
