joeldaugherty Posted August 12, 2012 Share Posted August 12, 2012 Ok guys ... 2003 Accord EX, A/C blower isn't working. HVAC controls light up and I can hear the vents moving when I switch setting. Compressor does not engage. The blower engages for like a second when ignition switch is in II position. Ran the self-diagnostic and it resulted in "N" - circuit problem (duh). hot-wired blower, it works great ... check tried new resistor, not the problem ... check under dash fuses ... check relays and fuses in under hood fuse box ... check I don't know what else to check. Ideas? Thanks! Link to comment Share on other sites More sharing options...
