ticolin1983 Posted August 10, 2012 Share Posted August 10, 2012 2000 Civic EX Coupe. Recently changed Thermostat, thermoswitch, radiator, and cleaned out the whole cooling system. Now the fan wont kick in so i had to jump it in order for it to turn on. I;ve checked all the relays and fuses and everything is fine. What could be causing this problem.????? Link to comment Share on other sites More sharing options...
Xeryon Posted August 10, 2012 Share Posted August 10, 2012 I'm tired and the name of the part to check next escapes me. I'm thinking temperature sending unit? You might have fouled/damaged the sensor flushing the system. Link to comment Share on other sites More sharing options...
