honda13456789 Posted July 31, 2012 Share Posted July 31, 2012 So from the reading ive done im still stuck because some say that on the 91 civic it is easier to just replace the manifold, but the problem is i already have replacement injectors. so in my case would it be worth it to just replace the injectors and do the extra work? and if so what are the exact steps to go about replacing them? and if not then what are the steps to take in fixig the problem all togher? i have already brough the car in and had it hooked to the machine and the results are bad injectors so now the problem is just getting them fixed.. Link to comment Share on other sites More sharing options...
Mordeca1 Posted August 12, 2012 Share Posted August 12, 2012 Yes, it would be easier to replace the manifold, but usually with an aftermarket manifold, you have to buy a larger throttle body. Skunk2 has both for around $375 each. Or, you could search for an OEM replacement manifold, which would be cheaper but used. It depends on the route you want to take. Link to comment Share on other sites More sharing options...
Humphries Posted August 19, 2012 Share Posted August 19, 2012 no.. it's easier just to take the fuel rail off and remove and replace the injectors.. wtf how would replacing an intake manifold be easier than that? dumbasses. Link to comment Share on other sites More sharing options...
