Accordguy713 Posted July 28, 2012 Share Posted July 28, 2012 Hello everyone. My name is Evan I am new to the forum and I am encountering problems with my Honda. I own a 2000 Accord Se and about 3 months ago the problems began. I purchased the car 4 yrs ago as a daily driver with no intention of doing any extra work to it. In May I replaced the radiator and hoses, bearing in the U-joints and the batterie. Now the check engine light is on with the maintenance required light flickering when I turn the car on. I have done some research and have found out that the model yr of my car is victim of a bad transmission. I am just looking for a cheap solution to my problem. I am going to get the trans serviced today with new fluid and filter. Thanks for the help. Link to comment Share on other sites More sharing options...
Xeryon Posted July 29, 2012 Share Posted July 29, 2012 Your transmission does not have a filter for one. You just drain and refill. Run it and drain and refill again. Get a read on the check engine code. Don't assume you have a transmission problem just because you read it on the internet and throw money at a non-existent issue. Oh, and you never said what the actual problem is. Link to comment Share on other sites More sharing options...
James Matteu Posted July 29, 2012 Share Posted July 29, 2012 bearing in the u joint? That's new. Yes, pull code and be objective. Link to comment Share on other sites More sharing options...
