ablaize14 Posted November 20, 2011 Share Posted November 20, 2011 Hey fellow forumers... I have a 96 civic with a bit of a shaky steering wheel while driving... I have found the rack and pinion was bad... I replaced it and had an alignment and wheel balance... But still shakes... I also found my axles are bad and replaced them... Now it still shakes... So I am a bit frustrated... I found my sway bar brushing are bad... Could this be the problem or does anyone else have some info on the matter... I am replacing them either way but just looking for some advice... Link to comment Share on other sites More sharing options...
Raley Posted November 20, 2011 Share Posted November 20, 2011 the place you brought the car to get the alignment/balancing did it wrong or bushings... Link to comment Share on other sites More sharing options...
janepaul Posted March 15, 2012 Share Posted March 15, 2012 even i am having the same issue help me with the solution guys please.. Link to comment Share on other sites More sharing options...
Karl Chen Posted October 13, 2012 Share Posted October 13, 2012 I recently obtained a 94 civic and I'm experiencing the same issue. A tire shop informs me that my rims are missing the "center rings" and that is what is causing the shaking. I need help in finding out what type of rims I have but am unable to upload a picture. The 'image' button on the post is asking for a url location? How do I upload an image file that is on my computer? Link to comment Share on other sites More sharing options...
airjordan223 Posted October 13, 2012 Share Posted October 13, 2012 You need to upload the pictures to a web hosting site first, then copy the URL link here. You can use photobucket, flickr, imgur etc to upload them. Link to comment Share on other sites More sharing options...
Karl Chen Posted October 13, 2012 Share Posted October 13, 2012 Thank you. Link to comment Share on other sites More sharing options...
Karl Chen Posted October 13, 2012 Share Posted October 13, 2012 Here are some photos of the rim. Can anyone tell me what make and model they are so I can order the center rings? Thanks. Sorry about the picture size. I keep getting an icon with a red 'x' in the middle when I try different links. This is the only one that would put the picture in the post. Any help in how to adjust the size would also be appreciated. Link to comment Share on other sites More sharing options...
Xeryon Posted October 13, 2012 Share Posted October 13, 2012 When they said you were missing the center rings they were not referring to the beauty cover over the lugs, they were referring to a hub ring. The center bore on your wheel is larger so that it will be a universal fit on several different brands of cars. You need a hub centric ring to properly center the wheel on the hub. The link below is an example. Don't buy those. Just check out the auction for information on how to get the proper measurements for the rings you need. http://www.ebay.com/itm/HUB-CENTRIC-RINGS-67-1-56-1-MM-HONDA-CIVIC-CRX-INTEGRA-/130557667201 Link to comment Share on other sites More sharing options...
Karl Chen Posted October 21, 2012 Share Posted October 21, 2012 Thank you. I'll give them a try. A garage I went to told me that I need new wheels and that the hub rings would probably not help but since they are so inexpensive I think I will try the hub rings first. Link to comment Share on other sites More sharing options...
Humphries Posted November 12, 2012 Share Posted November 12, 2012 balance tires, check if upper or lower ball joints are bad, check tie rod ends, get hubcentric rings, Link to comment Share on other sites More sharing options...
anthony916 Posted December 28, 2012 Share Posted December 28, 2012 balance tires, check if upper or lower ball joints are bad, check tie rod ends, get hubcentric rings, Link to comment Share on other sites More sharing options...
gunney Posted September 1, 2019 Share Posted September 1, 2019 Check inner tie rod ends. Small amounts of wear can be had to detect and check for. Link to comment Share on other sites More sharing options...
