bandaidgrenade Posted September 11, 2011 Posted September 11, 2011 Hi. I have a problem with my car. I recently bought a 98 civic. I went to get it inspected and they told me to run it through a drive cycle and come back since I have 3 codes that aren't ready. The Cat, O2, Evap. I drove it for about 5 to 6 minutes at 50 on the freeway. But when I got off the freeway and was heading home the car just shut down. No check engine light showed up until it died. Finally after about 15 minutes we got it started again. But now everytime I drive it to get it inspected it dies. I've replaced the distribitor, did a coolant flush (since the person I got it from decided to use water), replaced all the fuses, replaced the spark plugs, got a new upper o2 sensor, plug wires are like new and so is the batterey. After doing all of that it just died again while trying to run it through a new drive cycle. I'm very confused onto what could be causing it to die. If someone could help me out that would be great.
bandaidgrenade Posted September 11, 2011 Author Posted September 11, 2011 Someone just told me to try the crank sensor?
