Got-sol92 Posted August 29, 2011 Posted August 29, 2011 Well we all know how small the radiators are not only in the del sol but mostly in any civic. I was conjuring up an idea. I had taken out all the ac and ps components and left a big air gap in the front of the engine and I was thinking because my car has a slight habit of getting really hot is if you could add another radiator of the same size where the ac one was and make a "y" fitting for the hoses to go to both of them or just replace it with a new or used bigger one. What do y'all think?
Raley Posted August 29, 2011 Posted August 29, 2011 If you want to updrade, integra radiator... im guessing you might just need a replacent or a flush...
DelSolSweetie Posted August 29, 2011 Posted August 29, 2011 your car should be cooling fine with the factory radiator.. instead of buying another you should find your current problem and fix it
cmgogo Posted August 30, 2011 Posted August 30, 2011 ^^^^ this, The black sol I have is from new mexico and was run in the desert boosted on the stock 1/2 rad and doesnt have cooling problems, you have something else going on. When was the last time the water pump and t-stat were replaced? When was the last time the coolant was flushed?
