EKray Posted August 25, 2011 Posted August 25, 2011 hey peps wen i start my car it hesitates to start right up wen it does it feels like its gunna stall so i have to give it gas nd wen its on the road when i punch it i t feels like i get less power nd it waisting alot more gas i dnt think its burning right does n e 1 kno wat could b the problem?
kaleb123 Posted August 25, 2011 Posted August 25, 2011 fuel pump could be bad? or injectors need cleaned or replaced
DelSolSweetie Posted August 25, 2011 Posted August 25, 2011 1) please use proper ENGLISH or don't get on this forum again.. I dont know how you even have a driver's license when you need to go back to elementary school from what I THINK that post says you might just need to clean the injectors.. put 1/3 a can of seafoam in the gas tank next fill up.. then use 1/3 in the air intake system.. directions are on the can.. hopefully you can read it do you have any check engine lights? it could be something like an 02 sensor which would throw a code it's not the fuel pump
EKray Posted August 26, 2011 Author Posted August 26, 2011 I Dont think its the fuel pump nd check engine light is not on....nd WTF is seafoam?
EKray Posted August 27, 2011 Author Posted August 27, 2011 would that work cause my car sounds pretty bad
