kryptekz Posted August 21, 2011 Posted August 21, 2011 93 Del Sol The Driver side and rear window work fine. The passenger windows likes to randomly work. It is not b/c of the window lock button either. When the window does work, only the switch on the drivers side can roll it down, otherwise the switch on the passenger side is completely dead. I decided to disconnect the switch on the passenger side to see if it changed anything. It would still randomly stop working. So, could it be the main Power Window Switch on the driver side? Can a faulty driver side switch affect the passenger side regulators function? It's not the passenger windows motor since it rolls the window up fine and doesn't stutter, or appears to be weak. I rather not bring this to the dealer, since I think it might be a simple fix. I did replace the fuses and that did not fix the problem either. Thanks
cmgogo Posted August 22, 2011 Posted August 22, 2011 check the door harness, odds are you have a loose wire in the grey pin box.
