ladiciusskum Posted February 11, 2011 Share Posted February 11, 2011 OK i have a 90 ef hatch and its cable i have a ls motor and tranny but the transmission is hydro would a cable transmission bolt up to my ls motor or does it have to be a certain year Link to comment Share on other sites More sharing options...
cmgogo Posted February 11, 2011 Share Posted February 11, 2011 what motor is in it now? And as far as the transmission you will need to either convert the chassis to a hydro system or convert the trans to a cable (i would go hydro personally) Link to comment Share on other sites More sharing options...
Raley Posted February 11, 2011 Share Posted February 11, 2011 convert car to hydro, or you can replace that hydro tranny with a cable tranny. just an FYI, the cable will stretch and cause you to ride your clutch when your pedal is depressed. Link to comment Share on other sites More sharing options...
C92hatchX Posted February 12, 2011 Share Posted February 12, 2011 Just put a cable trans on, I've tried the cable to hydro chassis in my del and it was a pain I heard by doing a hydro in a cable car you won't have a speedo I may be wrong tho, all in all id slap a cable in there for an easy day Link to comment Share on other sites More sharing options...
Raley Posted February 12, 2011 Share Posted February 12, 2011 Swap a cable speedo in hydro car and you have a working gauge. It all depends on which kit you get... and hes doing the oposite then you. Link to comment Share on other sites More sharing options...
