holliday Posted January 9, 2011 Share Posted January 9, 2011 I recently bought a 94 Honda Passport. The vehicle runs good and is great. But I'm having problems with the 4x4. When I try to lock it in the front wheels don't pull. The light on the dash lights up saying that it is engaged but they aren't spinning. It does put the rear into low gear and high gear. If any one could help me it would be greatly appreciated. Thanks, Holliday Link to comment Share on other sites More sharing options...
pinkrimedpiggy Posted January 9, 2011 Share Posted January 9, 2011 I recently bought a 94 Honda Passport. The vehicle runs good and is great. But I'm having problems with the 4x4. When I try to lock it in the front wheels don't pull. The light on the dash lights up saying that it is engaged but they aren't spinning. It does put the rear into low gear and high gear. If any one could help me it would be greatly appreciated. Thanks, Holliday Is this you? when you shift it into 4x4 do you hear the transfer case? Link to comment Share on other sites More sharing options...
Xeryon Posted January 9, 2011 Share Posted January 9, 2011 The downside to your problem is the only thing honda about your passport is the H on the hood. If you are engaging the 4x4 and the wheels don't spin you have a transfer case problem, a front drive shaft failure or a u-joint failure. 4x4 systems are fairly simple really. Link to comment Share on other sites More sharing options...
pinkrimedpiggy Posted January 9, 2011 Share Posted January 9, 2011 have someone drive very slowly while you look under the car and see if the front drive lines are moving.. Link to comment Share on other sites More sharing options...
Raley Posted January 9, 2011 Share Posted January 9, 2011 Ill admit to not knowing the passport, but i know 4x4s. Does the passport have vaccum engagement like a 90s chevy? Link to comment Share on other sites More sharing options...
holliday Posted January 10, 2011 Author Share Posted January 10, 2011 Thanks for all the replies. Yes that is my post on car gurus but apparently people don't reply to you there lol. and no there are not any odd sounds coming from the transfer case. I drove it in a circle today while we watched the front drive shaft. It starts to spin but then stops. But as i said... The 4x4 light is coming on and the gear is engaging (like crawling). As for the vacuum lines I'm not sure. I haven't found em. Link to comment Share on other sites More sharing options...
Xeryon Posted January 10, 2011 Share Posted January 10, 2011 Your truck is a nissan pathfinder. make sure to keep that in mind when researching this. Link to comment Share on other sites More sharing options...
holliday Posted January 10, 2011 Author Share Posted January 10, 2011 Your truck is a nissan pathfinder. make sure to keep that in mind when researching this. I thought it was a honda passport or isuzu rodeo? Link to comment Share on other sites More sharing options...
Xeryon Posted January 10, 2011 Share Posted January 10, 2011 and that one too. i am a tard some days. ignore my earlier statement Link to comment Share on other sites More sharing options...
holliday Posted January 10, 2011 Author Share Posted January 10, 2011 so could i get parts for any of those in the same year and they fit? Link to comment Share on other sites More sharing options...
Xeryon Posted January 10, 2011 Share Posted January 10, 2011 the isuzu and the honda should be entirely interchangeable. to my knowledge the rodeo was the more popular vehicle so you may be able to find parts more easily down that path. Link to comment Share on other sites More sharing options...
holliday Posted January 10, 2011 Author Share Posted January 10, 2011 I'll keep that in mind. As for my 4x4 do you have any clue where I should atleast start? Link to comment Share on other sites More sharing options...
Xeryon Posted January 11, 2011 Share Posted January 11, 2011 transfer case flush/drain/refill. get the truck off the ground - lift or blocks, see if all four wheels move Link to comment Share on other sites More sharing options...
