jonno_zeke Posted December 17, 2010 Share Posted December 17, 2010 my wife totalled our 99 ex coupe. I salvaged the motor and trans, spindells brakes cvaxles engine wiring harness and pcm and exhaust. Is there anything missing? The goods are going into a 98 lx 4 door auto. Need experienced details on what needs to be done to complete the swap Link to comment Share on other sites More sharing options...
jonno_zeke Posted December 17, 2010 Author Share Posted December 17, 2010 so nobody has any idea how to do this? is that what i am to understand. c'mon somebody. I'm a ford tech. I only know so much about hondas. And this is no direct bolt in. Anybody? Link to comment Share on other sites More sharing options...
rocknskulls Posted December 25, 2010 Share Posted December 25, 2010 so nobody has any idea how to do this? is that what i am to understand. c'mon somebody. I'm a ford tech. I only know so much about hondas. And this is no direct bolt in. Anybody? ur taking the engine and tranny out of the 99 civic and putting it in a 98 civic? should just be a simple swap maybe have to change a motor mount or trans mount were they both auto? Link to comment Share on other sites More sharing options...
Trae%eh6 Posted December 26, 2010 Share Posted December 26, 2010 if they are both auto then it would be like cutting a cake. but if you are wanting to do a auto to mauanl swap that is something i have not done. i have a artcil in a mag that i can do a write up on it if you want but i need to know Link to comment Share on other sites More sharing options...
Raley Posted December 26, 2010 Share Posted December 26, 2010 Auto to manual swap is tricky.... if thats what it is ill post details. Link to comment Share on other sites More sharing options...
jonno_zeke Posted December 27, 2010 Author Share Posted December 27, 2010 Auto to manual swap is tricky.... if thats what it is ill post details. auto to manual Y7 replaced with Y8 v-tec wire harness replaced lx non-v-tec harness. spyndels and cv axles. clutch pedal and shifter and clutch master installed. do i need to swap the ignition switch aswell? Can i run a jumper to the nuatral safety bypass? anything else that i may need to get? Link to comment Share on other sites More sharing options...
Raley Posted December 27, 2010 Share Posted December 27, 2010 frack the clutch safty, just leave it in nutrual. Also you need to change passenger upper mount bracket or buy a conversion mount. Link to comment Share on other sites More sharing options...
jonno_zeke Posted December 27, 2010 Author Share Posted December 27, 2010 frack the clutch safty, just leave it in nutrual. Also you need to change passenger upper mount bracket or buy a conversion mount. Is that it? I seem to have plugs on my front wire harness for the front clip area, the headlights and blinkers and horns, I have plugs at the end of the harness that i have no idea where they go. And alldata is not a help at all Link to comment Share on other sites More sharing options...
Raley Posted December 27, 2010 Share Posted December 27, 2010 All the plugs your currently using are going to be used again. There isnt any added wiring other then knock. Link to comment Share on other sites More sharing options...
jonno_zeke Posted December 28, 2010 Author Share Posted December 28, 2010 All the plugs your currently using are going to be used again. There isnt any added wiring other then knock. sweet deal. thanx Link to comment Share on other sites More sharing options...
Raley Posted December 28, 2010 Share Posted December 28, 2010 Wait, i reread what i wrote, now i have to correct myself, you will be using wires already there but there will be extras on the auto trans, motor will be fine and there isnt a knock sensor. Only wire that im not sure about is reverse lights and the clutch wire.... but youll be fine. If ylou search google im pretty sure you will find a full write up on it, eg or ek will steer you in the right direction, thewy are almost the same. Link to comment Share on other sites More sharing options...
