92hondapreludesi Posted November 29, 2010 Share Posted November 29, 2010 I have a 92 honda prelude si with 4ws. It has an h23 motor in it with a 70mm throttle body, and im pretty sure thats it. I just bought the car so im not entirely sure. Anyways i plan to drop a turbo in it in the next few weeks and was wondering if there are any good how to websites. Also how much boost i should run on the stock internals. Link to comment Share on other sites More sharing options...
airjordan223 Posted November 29, 2010 Share Posted November 29, 2010 start here http://www.hondaforums.com/index.php?/topic/13909-turbo-necessities/ there are a lot of good links inside that as well. then come back if you have any other questions. Link to comment Share on other sites More sharing options...
HondaBro Posted July 29, 2011 Share Posted July 29, 2011 I wouldn't go any higher than 12 PSI if I were you. Link to comment Share on other sites More sharing options...
airjordan223 Posted August 1, 2011 Share Posted August 1, 2011 i would stop bumping old dead stanky threads if i were you Link to comment Share on other sites More sharing options...
lollipoptian Posted October 12, 2011 Share Posted October 12, 2011 Every little thing that you say or do. Cheap Herve Leger Cheap Herve Leger Dresses Herve Leger Skirts on Sale cosmetic bottles wholesale Link to comment Share on other sites More sharing options...
Gtjetta97 Posted April 1, 2012 Share Posted April 1, 2012 You should never run more than about 50% more power on stock internals. That means no more than 8 psi not 12!! Your stock cast pistons have small air bubbles in them (porosity) and they are very weak do to the method of construction from pouring into a mold. They most likely wouldn't even survive detonation on 8 psi. Forged however will punch right through detonation and you'll lose the head gasket instead. Also forged pistons will not flake off melted pieces of aluminum like cast will under boost. Stock rods are fine. Link to comment Share on other sites More sharing options...
