jdmfreak69 Posted October 7, 2010 Share Posted October 7, 2010 ok so heres the deal my lil bro bought a car off a guy its a 1996 civic ex but he has a d15b motor swapped in the motor head has two v tec solenoids and the v tec cracks around 6500 rpms and it barely pulls so im trying to figure out why there are two solenoids and why the v te doesnt crack correctly also what year the motor is and what car it came out of. the guy said it came off another civic 96 ex but i think he is full of crap. so if anybody knows anything please post here or email me please thanks email: jdmfreak69@gmail.com Quote Link to comment Share on other sites More sharing options...
EK HATCH Posted October 7, 2010 Share Posted October 7, 2010 3 stage D15B Vtec, its got 2 vtec solenoids, but there are 3 stages: Vtec-e Normal 16 valve mode regular SOHC Vtec To further clarify things these engines used a P2J ECU, the OBD1 plain old SOHC vtec D15Bs used a P08 Read more at http://www.honda-tech.com/showthread.php?p=43603912&kcplink=1 oh yeah and they come off 1991-1995 Honda CRX Del Sol Quote Link to comment Share on other sites More sharing options...
jdmfreak69 Posted October 7, 2010 Author Share Posted October 7, 2010 ok cause im running a 96-2000 civic ex ecu on the car right now and around 5500-6000 rpms where the v tec kicks the car kinda bogs down and slows. is that because of the ecu? \ would i just have to change the ecu to fix that and make the v tec work correctly? and would it be a 1.5 L or a 1.6 L motor???? Quote Link to comment Share on other sites More sharing options...
jdmfreak69 Posted October 7, 2010 Author Share Posted October 7, 2010 3 stage D15B Vtec, its got 2 vtec solenoids, but there are 3 stages: Vtec-e Normal 16 valve mode regular SOHC Vtec To further clarify things these engines used a P2J ECU, the OBD1 plain old SOHC vtec D15Bs used a P08 Read more at http://www.honda-tech.com/showthread.php?p=43603912&kcplink=1 oh yeah and they come off 1991-1995 Honda CRX Del Sol ok cause im running a 96-2000 civic ex ecu on the car right now and around 5500-6000 rpms where the v tec kicks the car kinda bogs down and slows. is that because of the ecu? \ would i just have to change the ecu to fix that and make the v tec work correctly? and would it be a 1.5 L or a 1.6 L motor???? Quote Link to comment Share on other sites More sharing options...
EK HATCH Posted October 7, 2010 Share Posted October 7, 2010 (edited) its a 1.5L and yeah if you switch the ecu it will run perfect get the p2J ecu and it will run good Edited October 7, 2010 by EK HATCH Quote Link to comment Share on other sites More sharing options...
jdmfreak69 Posted October 7, 2010 Author Share Posted October 7, 2010 its a 1.5L and yeah if you switch the ecu it will run perfect get the p2J ecu and it will run good will i need a specific year?? or will any 1991-1995 crx del sol ecu work? Quote Link to comment Share on other sites More sharing options...
EK HATCH Posted October 7, 2010 Share Posted October 7, 2010 i found this ecu it will work idk if you want to buy it but it will work i wish you luck my friend http://cgi.ebay.com/ebaymotors/96-98-HONDA-CIVIC-3-STAGE-VTEC-AUTO-P2J-ECU-JDM-D15B-_W0QQcmdZViewItemQQhashZitem33617dcbbaQQitemZ220678966202QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Quote Link to comment Share on other sites More sharing options...
jdmfreak69 Posted October 7, 2010 Author Share Posted October 7, 2010 i found this ecu it will work idk if you want to buy it but it will work i wish you luck my friend http://cgi.ebay.com/ebaymotors/96-98-HONDA-CIVIC-3-STAGE-VTEC-AUTO-P2J-ECU-JDM-D15B-_W0QQcmdZViewItemQQhashZitem33617dcbbaQQitemZ220678966202QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories thanks for the help bro you helped a lot Quote Link to comment Share on other sites More sharing options...
EK HATCH Posted October 7, 2010 Share Posted October 7, 2010 no problem anytime Quote Link to comment Share on other sites More sharing options...
jdmfreak69 Posted October 8, 2010 Author Share Posted October 8, 2010 i found this ecu it will work idk if you want to buy it but it will work i wish you luck my friend http://cgi.ebay.com/ebaymotors/96-98-HONDA-CIVIC-3-STAGE-VTEC-AUTO-P2J-ECU-JDM-D15B-_W0QQcmdZViewItemQQhashZitem33617dcbbaQQitemZ220678966202QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories ay bro i had another question you said its a 3 stage v tec does that mean that i should have 3 sollenoids on my engine?? Quote Link to comment Share on other sites More sharing options...
EK HATCH Posted October 8, 2010 Share Posted October 8, 2010 (edited) no it should only hav VTEC-E 1000rpm-2500rpm 16 valve mode 2500rpm-5500RPM Normal sohc vtec 5500rpm-7200rpm those are the 3 stages hope it helps Edited October 8, 2010 by EK HATCH Quote Link to comment Share on other sites More sharing options...
