miles11s Posted September 10, 2010 Share Posted September 10, 2010 After changing out the transmission fluid using Honda recommended oil, the transmission wont shift into 6th gear. I checked the fluid level and its full, Other gears shift fine as well as reverse. When trying to shift into 6th its like theres nothing there. Also after trying it makes the shifter slightly sticky like until shifting into different gear and it smooths out again. Anyone have any ideas Quote Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted September 13, 2010 Share Posted September 13, 2010 What did you use? Did you put enough in the trans? Quote Link to comment Share on other sites More sharing options...
