marauder228vw Posted August 23, 2010 Share Posted August 23, 2010 my tach is not working in my 94 si auto, but when i turn on the car it moves slightly and also my odometer stoped working , only th rpms work, any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
Xeryon Posted August 23, 2010 Share Posted August 23, 2010 You contradict yourself in your description. You stated your tach is not working, but you also note the rpms are working. The tach measures your rpms. So which is it, the tachometer is working or not working? Makes a big difference in what could be going on. Quote Link to comment Share on other sites More sharing options...
SolMusic Posted August 23, 2010 Share Posted August 23, 2010 C'mon man, u know he just means the speedometer. Well, I'm guessing so anyway. The Speedo unit is easy enough to remove, take it out and check the connections, that'd be the first thing I'd do. For removal instructions, go on http://www.teamdelsol.com/ , then click on 'Information' | 'How-To' | 'Install indiglo Dials', then there is a link on that page on how to remove the cluster. (Sorry I would just link the page, fking teamdelsol has got their website set so that it doesn't show you the http of the page your on!). Quote Link to comment Share on other sites More sharing options...
Trae%eh6 Posted August 23, 2010 Share Posted August 23, 2010 do you drive the car for a long period of time. bc if your having a promblem in the charging system the speedo will not work. also does your radio go out Quote Link to comment Share on other sites More sharing options...
Xeryon Posted August 23, 2010 Share Posted August 23, 2010 (edited) Actually seb, I was quite confused. He noted two different devices in his description: Tachometer and Odometer but made no specific reference to Speedometer. Just wanted a clarification as to which parts work, which are 100% non-responsive and which are 'working' just not working correctly. Edited August 23, 2010 by Xeryon Quote Link to comment Share on other sites More sharing options...
marauder228vw Posted August 23, 2010 Author Share Posted August 23, 2010 everything works except for the speedometer and the thing that reads the miles. The rpm meter and everything else works fine, just when i start the car , the speedo jumps a bit bu does nothing else.When i purchased the car, it was not working. yes i do drive about 64 miles a day but have no other issues or with the radio, it works just fine. Quote Link to comment Share on other sites More sharing options...
Xeryon Posted August 23, 2010 Share Posted August 23, 2010 The tach and the speedo are controlled by the same fuse, so power really isn't a concern then. Hell, the entire cluster operates off of the same wiring harness. Next thing I would be doing is buying a cluster and pulling the speedo out and switch it with yours. I would guess the odometer actually is working, just the speedo part is broken. the odometer is an 'internal' part of the speedo and is itself mechanical but dependent on the speedo to function. Quote Link to comment Share on other sites More sharing options...
Trae%eh6 Posted August 24, 2010 Share Posted August 24, 2010 The tach and the speedo are controlled by the same fuse, so power really isn't a concern then. Hell, the entire cluster operates off of the same wiring harness. Next thing I would be doing is buying a cluster and pulling the speedo out and switch it with yours. I would guess the odometer actually is working, just the speedo part is broken. the odometer is an 'internal' part of the speedo and is itself mechanical but dependent on the speedo to function. ok in a ek i know this that the rpm and speedo are not on the same fuse. bc when i was popping my fuse the rpm was still working. i would check the speedo sensor it is on the trans on top. check that out. see if its undone or lose Quote Link to comment Share on other sites More sharing options...
tallhamer88 Posted August 24, 2010 Share Posted August 24, 2010 Sounds like speed sensor. Quote Link to comment Share on other sites More sharing options...
Xeryon Posted August 24, 2010 Share Posted August 24, 2010 I stand corrected on the fuse arrangement, Trae. So we have: speed sensor broken or loose, and speedometer malfunction. Quote Link to comment Share on other sites More sharing options...
tallhamer88 Posted August 24, 2010 Share Posted August 24, 2010 I stand corrected on the fuse arrangement, Trae. So we have: speed sensor broken or loose, and speedometer malfunction. only issue is speed sensor is pretty much inside your tranny. Quote Link to comment Share on other sites More sharing options...
Trae%eh6 Posted August 24, 2010 Share Posted August 24, 2010 I stand corrected on the fuse arrangement, Trae. So we have: speed sensor broken or loose, and speedometer malfunction. srry if i seemed like a as$ i was not trying to. i just went thought a really bad promble with the ek so that is the only reason i knew about it Quote Link to comment Share on other sites More sharing options...
marauder228vw Posted August 24, 2010 Author Share Posted August 24, 2010 great so that mean i would have to take it apart, blah!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!. i might as well just trade the thing Quote Link to comment Share on other sites More sharing options...
Xeryon Posted August 24, 2010 Share Posted August 24, 2010 why? you bought a 17 year old car. did you not expect to have to repair at least a few things? do the superduper cheapout method: buy a gps with a speedometer in it. Quote Link to comment Share on other sites More sharing options...
SolMusic Posted August 24, 2010 Share Posted August 24, 2010 (edited) great so that mean i would have to take it apart, blah!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!. i might as well just trade the thing U lazy bugger, get off your ass n fix it yourself, or get someone to fix it. Talk about a throwaway society, geeez. Edited August 24, 2010 by SebSol Quote Link to comment Share on other sites More sharing options...
marauder228vw Posted August 25, 2010 Author Share Posted August 25, 2010 U lazy bugger, get off your ass n fix it yourself, or get someone to fix it. Talk about a throwaway society, geeez. lmao ,actually 10 minutes after posting it on craigslist for trade, i got a couple of good offers which caught my eye, one being a 93 del sol si MANUAL!!!!! a college girl wants an automatic and also so not entertaining was a 97 acura cl 2.2 5 speed. Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 25, 2010 Share Posted August 25, 2010 you dont have to take the tranny apart for the speed sensor mine was broke when i got my car out of the shop and a friend had a broke del so he took his speed sensor off and put it on mine in a few minutes Quote Link to comment Share on other sites More sharing options...
SolMusic Posted August 25, 2010 Share Posted August 25, 2010 (edited) lmao ,actually 10 minutes after posting it on craigslist for trade, i got a couple of good offers which caught my eye, one being a 93 del sol si MANUAL!!!!! a college girl wants an automatic and also so not entertaining was a 97 acura cl 2.2 5 speed. trade. See if college girl comes with it too... haha why people would even contemplate buying an automatic baffles me. i know most yanks dunno what a gear lever is for some reason (well, compared to over here), but still, fook having an auto unless it was for medical reasons. Edited August 25, 2010 by SebSol Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 26, 2010 Share Posted August 26, 2010 sometimes you find something for too good of a deal to pass up.. even if it is auto.. i'd take a well maintained auto del before i bought a trashed manual Quote Link to comment Share on other sites More sharing options...
SolMusic Posted August 26, 2010 Share Posted August 26, 2010 sometimes you find something for too good of a deal to pass up.. even if it is auto.. i'd take a well maintained auto del before i bought a trashed manual I'd look harder. Quote Link to comment Share on other sites More sharing options...
Xeryon Posted August 26, 2010 Share Posted August 26, 2010 i would go out of my way to buy the trashed manual instead. not only would it give me something to do but the trashed car would be a lot cheaper. Quote Link to comment Share on other sites More sharing options...
marauder228vw Posted August 26, 2010 Author Share Posted August 26, 2010 well im going to see it today, its a 93 si but with a d16y8 black , so lets see how that goes. ill keep you guys informed Quote Link to comment Share on other sites More sharing options...
marauder228vw Posted August 27, 2010 Author Share Posted August 27, 2010 Well,it had no a/c, and it made wierd noise as I drove off with it, like a whine but I have to seriously have to think about cuz my car is mechanically perfect Quote Link to comment Share on other sites More sharing options...
