oldcivic Posted August 21, 2010 Share Posted August 21, 2010 1989 Honda Civic: Problem: Filled up gas. Went to crank it. Dash lights come on like all is normal. Ignition to position three (where it normally turns over).... Nothing. It was running fine. Put a brand new battery in the day before. Checked all fuses. I've inspected the wires and don't see any obvious signs of wear/abrasion. Pulled starter and had it tested (it passed A-Okay). I tried putting a new ignition switch and main relay in this morning to no avail. So I've done everything I know about... Fuses are good, ignition switch is good, main relay is good, wires look okay, and starter is functioning. I'm at a loss. I'm still wondering if it is a control or relay (ex. if the clutch is up it won't let you start the car). Any ideas out there will be much appreciated? Thanks, Will Quote Link to comment Share on other sites More sharing options...
SAMiAM92O Posted September 1, 2010 Share Posted September 1, 2010 1989 Honda Civic: Problem: Filled up gas. Went to crank it. Dash lights come on like all is normal. Ignition to position three (where it normally turns over).... Nothing. It was running fine. Put a brand new battery in the day before. Checked all fuses. I've inspected the wires and don't see any obvious signs of wear/abrasion. Pulled starter and had it tested (it passed A-Okay). I tried putting a new ignition switch and main relay in this morning to no avail. So I've done everything I know about... Fuses are good, ignition switch is good, main relay is good, wires look okay, and starter is functioning. I'm at a loss. I'm still wondering if it is a control or relay (ex. if the clutch is up it won't let you start the car). Any ideas out there will be much appreciated? Thanks, Will Sorry, dude, no idea. Quote Link to comment Share on other sites More sharing options...
pumpkin civic Posted September 12, 2010 Share Posted September 12, 2010 i had similar problem when i still had my d series it was the stock motor in my 95 civic anyways i disconnected my battery to install a new stereo and went to hook the battery back up and turn the ignition and all the lights and normal starting up noises happened and tried to crank and nothing no sound nothing. it took me three days to figure out it was a bad ground. and by bad i mean slightly loose. i over looked it cause it was attached but loose. so check all your grounds. and let me now what you find out. good luck Quote Link to comment Share on other sites More sharing options...
fishindude911 Posted September 15, 2010 Share Posted September 15, 2010 i had the same problem on my civic, check your ground wires and the ground wires going to distributor Quote Link to comment Share on other sites More sharing options...
JC102024 Posted October 26, 2010 Share Posted October 26, 2010 1989 Honda Civic: Problem: Filled up gas. Went to crank it. Dash lights come on like all is normal. Ignition to position three (where it normally turns over).... Nothing. It was running fine. Put a brand new battery in the day before. Checked all fuses. I've inspected the wires and don't see any obvious signs of wear/abrasion. Pulled starter and had it tested (it passed A-Okay). I tried putting a new ignition switch and main relay in this morning to no avail. So I've done everything I know about... Fuses are good, ignition switch is good, main relay is good, wires look okay, and starter is functioning. I'm at a loss. I'm still wondering if it is a control or relay (ex. if the clutch is up it won't let you start the car). Any ideas out there will be much appreciated? Thanks, Will Have you figured out your starting issue? If not I have a suggestion, bc I had the same problem. Quote Link to comment Share on other sites More sharing options...
