marauder228vw Posted August 18, 2010 Share Posted August 18, 2010 Hello, I recently acquired a 94 del sol si automatic, but im not feeling it. what do i need to get this swap done? And also, my speedo doesnt work, only my tach, would i need to replace it? and also, how do i know my vtec is working because i dont feel it kick in, thanks Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 18, 2010 Share Posted August 18, 2010 (edited) speedo: could be a number of things.. i'm sure google might help.. could be messed up cable or a speed sensor conversion: you'll need all the master cylinders and pedal assembly of couse.. along with the new ecu etc etc.. i'm sure google could provide a full write up vtec is not a magical force that is SO different you will 'feel it'.. probably should engage about 55004800 rpm.. check wiki dseries for sure Edited August 18, 2010 by DelSolSweetie Quote Link to comment Share on other sites More sharing options...
marauder228vw Posted August 18, 2010 Author Share Posted August 18, 2010 speedo: could be a number of things.. i'm sure google might help.. could be messed up cable or a speed sensor conversion: you'll need all the master cylinders and pedal assembly of couse.. along with the new ecu etc etc.. i'm sure google could provide a full write up vtec is not a magical force that is SO different you will 'feel it'.. probably should engage about 5500 rpm.. check wiki dseries for sure thanks, it suppose to kick in at 4800rpm but i dont fell it. ive been in my friends and you can definetly tell with it engages. Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 18, 2010 Share Posted August 18, 2010 (edited) vtec is a crossover between cam profiles.. you should not be able to actually 'feel' it.. it helps out on top end.. i suppose you could be talking about the not feeling a loss of power.. but its should be a smooth change over you can 'hear' it if you have certain mods such as full exhaust and intake but even that isn't a guarantee.. we get numerous questions of 'i cant hear vtec' or 'i cant feel it'.. if you are concerned that it is not working i believe there is a way to hook up a check light to it.. we also have an entire thread in the engine building section on 'what to check if vtec isnt working' also, vtec is not some magical force that makes hondas faster.. every car maker has their own version of it.. it helps out on top end so you dont just run out of power at 5k Edited August 18, 2010 by DelSolSweetie Quote Link to comment Share on other sites More sharing options...
tallhamer88 Posted August 19, 2010 Share Posted August 19, 2010 if you go to memberlist look for repsol he did it and can really help you out with it. Him and his friend brandon said they would help me do mine. but i deciede to put money else where for now. I got quoted 900 with LSD Tranny at Jtune Auto. Quote Link to comment Share on other sites More sharing options...
marauder228vw Posted August 19, 2010 Author Share Posted August 19, 2010 if you go to memberlist look for repsol he did it and can really help you out with it. Him and his friend brandon said they would help me do mine. but i deciede to put money else where for now. I got quoted 900 with LSD Tranny at Jtune Auto. thanks, greatly appreciate it Quote Link to comment Share on other sites More sharing options...
