Trae%eh6 Posted August 18, 2010 Share Posted August 18, 2010 ok so im throwing a code the number is 1298 and its called a IDM code so can yall help. its on a 97 ek d16y8 Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 18, 2010 Share Posted August 18, 2010 P1298 Electrical Load Detector Circuit High Voltage My guess would probably the alternator LOL i dont trust the autozone tests much or alternator fuse like cranny said (i think it was cranny) and this was found in first google search: http://www.engine-light-help.com/honda-check-engine-light.html i expect better from you:laugh: Quote Link to comment Share on other sites More sharing options...
Trae%eh6 Posted August 18, 2010 Author Share Posted August 18, 2010 yea yea yea me too sarah. i found it later that night. but was going to see what ppl said. but here is the other than i just put a new atler on. so could it be bc im throwing a o2 code to. bc in the thing i found it said if you are throwing more than one code that it could be just bc of that. so what do you think Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 18, 2010 Share Posted August 18, 2010 when my tps and map got plugged up backwards it was throwing all kinds of crazy codes lol did you check the fuse like cranny said? and change the 02 sensor if your throwing a code lol Quote Link to comment Share on other sites More sharing options...
Trae%eh6 Posted August 19, 2010 Author Share Posted August 19, 2010 ok so this is becoming a big fracking promble and im getthing piss. as you know i changed the alter. well it was still not working right. i had music going and went to start my car and it would not start. so i push it off. so it starts then dies about 30 seconds later. so i change out the wire from the alter that goes to the fuse box. jumped the car off and it worked fine. and the speedo started working again. and then about 2 miles into it. it stops working again. and now the battery is shot again so what the hell do yall think this could be im need of some real help. and the battery light doesnt come on saying that it dieing Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 19, 2010 Share Posted August 19, 2010 did you check the fuse and grounds Quote Link to comment Share on other sites More sharing options...
Trae%eh6 Posted August 20, 2010 Author Share Posted August 20, 2010 yes i did thank you evey much lol. so i was talking to this guy today and he said that my ignition is the promble. so i looked in a haynes manual and there is a wire that goes from the alter to the ignition. but here is were it gets odd. he said that it was this so have any of you replaced this b4 and heard of it going out on ek's Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 20, 2010 Share Posted August 20, 2010 no only time i had a problem of battery draining was when i had a bad relay and when my alternator went out.. only time it died while driving and speedo messed up was when the alternator died random question: do you think your speed sensor could be messed up? dont think that would affect the car while driving though (not drain battery while driving at least.. it could though..) Quote Link to comment Share on other sites More sharing options...
Trae%eh6 Posted August 20, 2010 Author Share Posted August 20, 2010 yes you are right it will not mess up the way the car runs.but the other day it worked for a few mins. im going to change that out and see what happends but thank you. give your self a rep point for this if you know how to you have been alot of help Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 20, 2010 Share Posted August 20, 2010 i havent been very much help lol dont worry though.. its probably something stupid you just overlooked Quote Link to comment Share on other sites More sharing options...
