motortrend Posted August 6, 2010 Share Posted August 6, 2010 I have a 92 accord lx,I just changes the ac and alt belt.the problem im haven now is that the squeek when startind the engin in the morming and after work.Could the belts be to tight or to loose,i dont know which one to go by. Link to comment Share on other sites More sharing options...
Turtlehead Posted August 6, 2010 Share Posted August 6, 2010 Probably the a/c - alternator belt is loose. Either that it is the quality of the belt that was used. Adjust it a little tighter and try it again the next day or two. Re-tighten it if it continues. I believe the belt deflection should be around 10mm. You do not want to make it too tight as you can damage the bearings in the alternator and/or the a/c pump. Link to comment Share on other sites More sharing options...
