magician300 Posted August 3, 2010 Share Posted August 3, 2010 (edited) Hello to all! To give a brief background I have a 2001 Honda Accord that has about 148,000 miles on it; bought it brand new on July 4th, 2001. The car has been nothing but superb for me and given me no problems at all up until this point. I went for my state inspection and my check engine light was on; Honda ran a diagnostic check on it and came back with the code "P0135" stating it was the "O2 Sensor Heater Circuit; bank 1 sensor 1. Will need to replace Primary I2 Sensor based upon code" I am a car novice at best and know really nothing about cars except how to drive them and put gas in them. My question is they want $400 to replace this part and I am sure it can be done for much less.. is this a simple fix? Are there any guides that can walk me through doing this? How do I know I'm getting the right part? I was also told that my timing belt is starting to wear down and should be replaced soon. Are there any other belts or items I should look at replacing along with the timing belt? Any information that can be provided would be greatly appreciated. Thanks in advance! - Joe Edited August 3, 2010 by magician300 Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 3, 2010 Share Posted August 3, 2010 timing belt and water pump depending on where it is and how much the part costs it could be $400.. i know for my 93 an 02 sensor is $80-100 Quote Link to comment Share on other sites More sharing options...
OTiS Posted August 4, 2010 Share Posted August 4, 2010 i agree with sarah. if you replace the timing belt make sure you change the tensioner and water pump. the o2 sensor isnt hard to change. any parts store should have the socket to fit the o2 sensor. when you put the new o2 sensor in make sure you use some anti-seize so if you have to replace it again later on it wont be a pita to get out. im assuming its the one on the exhaust manifold so it should be easy to get to Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 4, 2010 Share Posted August 4, 2010 i know our cars only have the one but i dont know about older ones i agree with the anti seize.. my old o2 in my exhaust manifold was i think rusted into it.. just bought a new one with the new header Quote Link to comment Share on other sites More sharing options...
magician300 Posted August 4, 2010 Author Share Posted August 4, 2010 Thank you both for the replies it is greatly appreciated! I will be looking into replacing these items soon and will update with progress or questions. Quote Link to comment Share on other sites More sharing options...
magician300 Posted August 4, 2010 Author Share Posted August 4, 2010 (edited) So after doing a little bit more research on the O2 sensor it appears my car has two of them; one on the exhaust manifold and one on the catalytic converter. The specific error code I found online was this: "P0135 Front HO2S Heater Circuit Fault (Sensor 1)" Any idea which O2 sensor I may need to replace based upon this information? Edited August 4, 2010 by magician300 Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 4, 2010 Share Posted August 4, 2010 I would think the one on the exhaust manifold.. why doesn the code just say 'o2 sensor'.. such a pain not 100% sure though Quote Link to comment Share on other sites More sharing options...
magician300 Posted August 4, 2010 Author Share Posted August 4, 2010 (edited) Is the exhaust manifold near the front motor mount? I ask because I took my car to get inspected and that had to be replaced. When I left the lot is when the check engine light came on and I was diagnosed with this code. I am thinking there is a good chance I may not even need a new O2 sensor but think maybe they didn't put it back properly. Would they need to remove the sensor or work near it if replacing a front motor mount? I just find it highly coincidental that this car has 148,000 miles on it and literally has never given me a single problem and the moment I leave the lot is when this occurs. Edited August 4, 2010 by magician300 Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 4, 2010 Share Posted August 4, 2010 exhaust manifold comes out of the cylinder head.. most likely in front of motor on a honda Quote Link to comment Share on other sites More sharing options...
queensjay Posted August 4, 2010 Share Posted August 4, 2010 Easiest thing is just ot take it to autozone. they will check it for free. Quote Link to comment Share on other sites More sharing options...
