civic junky Posted August 1, 2010 Share Posted August 1, 2010 hello everybody: my ignition rotor was going bad, SO I REPLACED THE ROTOR AND CAP BUT NOW THE CAR WONT START. THERES JUICE IN THE SPARK PLUG WIRES AND THEY'RE IN THE RIGHT ORDER ON THE CAP. I MIGHT OF THROWN OFF THE DIZZY TIMING. ANY IDEAS HOW TO FIX IT. THANK YOU ALL Quote Link to comment Share on other sites More sharing options...
C92hatchX Posted August 2, 2010 Share Posted August 2, 2010 (edited) IS YOUR FUEL PUMP KICKING ON!! AND MAKE SURE YOUR NOT 180 DEGREES OUT OF TIME!!!!!!!!!!!!! Edited August 2, 2010 by C92hatchX Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 2, 2010 Share Posted August 2, 2010 make sure you pushed the plugs (not just wires.. there should be a couple plugs that go on the dizzy) on the cap on all the way if his motor is like my zc then the rotor only came off one way and only went on one way.. so it should be 180 out cause he shouldnt have touched the actual dizzy but i've seen people mess up simpler jobs then this how do you KNOW its getting 'juice' in the wires.. did you actually check it or assume? Quote Link to comment Share on other sites More sharing options...
