OldSchool007 Posted July 31, 2010 Share Posted July 31, 2010 My brake pedal has started a new trick. When I am stopped with the foot and the brake it gradually begins going closer to the floor the longer I keep pressure on it. If I don't continue pushing down the brakes release and the car begins to roll. So far the system has been bled with an automatic bleeder and mechanical been bled, as we as replacing the brake lines with SS lines. There are no visible leaks, so I am wondering if this would be a master cylinder issue, or if something else could be causing this? Link to comment Share on other sites More sharing options...
mpearce1974 Posted August 1, 2010 Share Posted August 1, 2010 My brake pedal has started a new trick. When I am stopped with the foot and the brake it gradually begins going closer to the floor the longer I keep pressure on it. If I don't continue pushing down the brakes release and the car begins to roll. So far the system has been bled with an automatic bleeder and mechanical been bled, as we as replacing the brake lines with SS lines. There are no visible leaks, so I am wondering if this would be a master cylinder issue, or if something else could be causing this? Master cylinder Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 2, 2010 Share Posted August 2, 2010 +1 Link to comment Share on other sites More sharing options...
OldSchool007 Posted August 3, 2010 Author Share Posted August 3, 2010 Master cylinder was replaced today and that fixed the issue. So, I have owned the car for a month and a half and the brakes have now been flushed 3 times. I must have the cleanest brake internals on a Del Sol at this point. Link to comment Share on other sites More sharing options...
