civic junky Posted July 29, 2010 Share Posted July 29, 2010 Hello everyone. I have an issue with my car, and any helpful input will be apriciated. My car is a 5 speed stick shift. The issue I'm having is that in any gear when I put pedal to the floor the car stalls or sumbles. But when in neutral it revvs up just fine. I'm thinking clutch, but just whant some opinions. Thank you in advance Link to comment Share on other sites More sharing options...
DelSolSweetie Posted July 29, 2010 Share Posted July 29, 2010 is it throwing codes when you are not tryin to floor a honda does it run correctly is it disengaging/engaging properly what have you recently done to the car are there any other symptoms Link to comment Share on other sites More sharing options...
civic junky Posted July 29, 2010 Author Share Posted July 29, 2010 is it throwing codes when you are not tryin to floor a honda does it run correctly is it disengaging/engaging properly what have you recently done to the car are there any other symptoms Is not throwing codes, if I take it ez on the gas it runs fine,it ingages and disengages fine, I just put in a pacesetter exhaust header. No other symptoms Link to comment Share on other sites More sharing options...
SpeedDemon Posted July 29, 2010 Share Posted July 29, 2010 how long have you been driving a 5 speed? you may be releasing the clutch too fast and its not getting enough time to pick the revs up so it stalls Link to comment Share on other sites More sharing options...
DelSolSweetie Posted July 29, 2010 Share Posted July 29, 2010 i know you said it isnt throwing codes but are you sure you installed the 02 sensor back correctly after header install Link to comment Share on other sites More sharing options...
civic junky Posted July 29, 2010 Author Share Posted July 29, 2010 how long have you been driving a 5 speed? you may be releasing the clutch too fast and its not getting enough time to pick the revs up so it stalls That's not my case. But thanks Link to comment Share on other sites More sharing options...
civic junky Posted July 29, 2010 Author Share Posted July 29, 2010 i know you said it isnt throwing codes but are you sure you installed the 02 sensor back correctly after header install Yeah its in there right. Link to comment Share on other sites More sharing options...
