mnea Posted July 17, 2010 Share Posted July 17, 2010 Where exactly on the cylinder block do I find the "Drain Bolt"as mentioned in the service manual in the 4th step of "Engine Coolant Refilling and Bleeding" AND what size & type of washer do I use for replacement? Quote Link to comment Share on other sites More sharing options...
cmgogo Posted July 17, 2010 Share Posted July 17, 2010 well that would appear to be next to the oil filter. AS far as washer goes, take it to your local harware store and find one that is the same or just reuse the old one. Personally i just drain the system from the drain on the bottom of the radiator. Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted July 17, 2010 Share Posted July 17, 2010 im with cory Quote Link to comment Share on other sites More sharing options...
