Birdman Posted July 15, 2010 Share Posted July 15, 2010 My sister has a 2004 Accord that does not start. Starter motor makes noise when inside and works fine when bench tested, but the engine still does not crank. No broken teeth on the flywheel or the starter gear. Need help ASAP. Link to comment Share on other sites More sharing options...
Turtlehead Posted July 16, 2010 Share Posted July 16, 2010 Could be the ignitor or the PGM-FI relay. I assume the engine is cranking but the car will not start. If it is not craking then there may be a loose connection from the battery or possibly a bad battery. There are other potential causes but these are "the most common." Link to comment Share on other sites More sharing options...
Birdman Posted July 16, 2010 Author Share Posted July 16, 2010 The engine is not cranking. I will try switching the batteries and see if that does anything. I also tried connecting the jumper cables to test the starter not only into the battery, but from the block and the power cable to the starter to see if there was any connection problems, but it still worked that way. Link to comment Share on other sites More sharing options...
