AIU Posted May 15, 2010 Share Posted May 15, 2010 ok I have a 99 gsr that i rebuilt when the car was just a shell. I swapped in a b18c1 motor from a 2000 gsr in my car and I am using a obd2a ecu. The problem that I am having is that none of my gauges are working. I read from a few other forums that to solve this problem that I would have to use a ecu harness to convert from obd2a to to obd2b with a obd2b ecu to fix the problem. But I also know that the obd2b ecu's have an emoblizer. So I'm thinking that if I do the obd2a to obd2b convert that the car won't start because of the emobilizer. has anyone ran into this problem before or have any suggestions Quote Link to comment Share on other sites More sharing options...
HONDA CRX 88 SI Posted May 16, 2010 Share Posted May 16, 2010 Get a p72 with a conversion harness from obd2 to obd1 and they should work the only thing you will need to do is connect a wire from the tach signal to the cluster and it will work cause if do not when you rev over vtec your tach will not work. Quote Link to comment Share on other sites More sharing options...
SIR_VTEC Posted June 29, 2010 Share Posted June 29, 2010 (edited) check your speed cables in the back of your gauge cluster, it is either disconnected or needs a replacement Edited June 29, 2010 by SIR_VTEC Quote Link to comment Share on other sites More sharing options...
