Killtodie Posted May 12, 2010 Share Posted May 12, 2010 So I was getting my suspention overhauled at a shop about 3 years ago, I had bad bushings all around my front end, including engine mounts. I initally asked for poly bushings for the control arms and such, but with a bit of a mix up I ended up with poly engine bushings as well. Now I'm getting really sick of them, tooo much engine vibrations, glove box shackes, hood latch keeps loosning up so the hood shakes, now my gauge panel is starting to vibrate. Not to mention the extra engine noise. Is there a DIY on replacing engine mounts? They seem easily accesible, do I just need to support the engine and swap them? Do I need a hoist or can I just jack it at the oil pan, it seems thick enough. Let me know please! Quote Link to comment Share on other sites More sharing options...
frostedflake Posted May 12, 2010 Share Posted May 12, 2010 you can usually use a jack under the oil pan with a piece of wood so it doesn't bend the pan. If you lift the weight off of the mounts its just a matter of unbolting and swapping them out. The only one that is a pain in the ass to get to is the rear one. It is in the back and its bolted to a crossmember. I don't know if you just want to replace the two front ones or all three. Just make sure you get the right ones, you did not specify if your car is a manual or auto, just make sure you get the correct mounts. Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted May 12, 2010 Share Posted May 12, 2010 ^ he is right. just be very careful when supporting it. its a better idea to use an engine hoist if you have one. less stress on engine componets. use both and it makes it even better. the rear one you may have to climb under the car for, but i doubt it. the only other thing you may run into is swapping the polyeurethane mounts themselves. you may have to have a shop press them out and press new ones in. shouldnt take long though Quote Link to comment Share on other sites More sharing options...
Killtodie Posted May 12, 2010 Author Share Posted May 12, 2010 Its manual, the rear one too. I plan on replacing teh entire unit, new mounts come with the bushing already installed, no burning/pressing necessary Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted May 12, 2010 Share Posted May 12, 2010 sweet. makes it ten times easier. just get an engine hoist if you can(you can rent them for cheap) and lift the motor enough to get the mount out, replace it with a new one, and move onto the next. Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted May 12, 2010 Share Posted May 12, 2010 If you do one at a time engine hoist is over kill. Quote Link to comment Share on other sites More sharing options...
Killtodie Posted May 12, 2010 Author Share Posted May 12, 2010 If you do one at a time engine hoist is over kill. Yeah, one at a time, just wondering if the pan is strong enought to support the engine Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted May 12, 2010 Share Posted May 12, 2010 (edited) Yeah, one at a time, just wondering if the pan is strong enought to support the engine Its not like each mount is supporting whole engine. DS Engine mount, and PS trans mount are doing 90% of the work of holding motor and trans up. The other ones are to keep engine more or less from rotating, absorb the energy and torque. The front and back you can do and will hardly see motor move, especially if all mounts are as rigid as you say. You may have to play with a jack under trans to help line up on installing, then on trans mount you can do with jack under tranny as well, then like I said the other 3 mounts will hold up most of the weight and jack under oil pan with 2X4 will be fine for DS engine mount. No problems! Edited May 12, 2010 by mpearce1974 Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted May 14, 2010 Share Posted May 14, 2010 what torque? and i was just saying hoist for safety. that way if somethign goes wrong with the jack, there is that much more to hold the engine Quote Link to comment Share on other sites More sharing options...
