millersmm76 Posted May 11, 2010 Share Posted May 11, 2010 (edited) where is the O2 sensor located on a 2004 Honda Civic? Is it hard to replace? Edited May 11, 2010 by millersmm76 Quote Link to comment Share on other sites More sharing options...
Killtodie Posted May 11, 2010 Share Posted May 11, 2010 There are two, one directly out the exhaust manifold another in the catalytic converter. The one in the cat might be hard to pull out, you will need a special tool to get out the one in the cat, otherwise a 21mm wrench will work. Just soak it in PB Blaster and see if you can get them out, if your slim and your car isnt dropped, you can get underneath without jacking up the car. Quote Link to comment Share on other sites More sharing options...
