adjust idle
mongo
yes
if you follow the throttle cable.. up around the TB and around the fuel injector there is a screw holding the bracket that holds the throttle cable.. you can adjust it around there
that was probably confusing... but you'll figure it out
Edited by DelSolSweetie
the Haynes says to unplug the IAC and adjust the screw next to it,,,i can turn it two complete times and still wont raise rpms,,,then it says to reconnect the plug, pull the back up fuse and recheck,,,,when my a/c comes on the rpms drop to 0 and raise to 1500 untill i power off the a/c...may have to clean the IAC or replace it,,dont know..........but thanks for your response,,,,,,,,,,,,till i learn about Hondas,,, all help is appreciated.
Edited by mongo
You are so right,,,I found a stop screw under the return spring,,but,,,,how the hell do u turn it,,,,,no slot for screw driver,,and i tried needle nose and cant get a good grip on it,,,,any tricks?
There is a allen wrench opening in the bottom of the adjustment screw, and you need to hold screw then back nut off to desired point then tighten screw til idle is where you want it, then snug nut back up while holding with allen wrench.
you were NOT touching the screw on the TB were you?
bad...I was told by honda guru around here NEVER touch the screw on the TB unless you have done everything else.. and even if you do make sure you remember EXACTLY how much you turned it
Was this directed at me? I am referring to the throttle stop screw. ( or what ever you call it)
OK, got it set, idle is much better,,,I was doing what the Haynes said about adj idle and page 1-27 , pic 30.b, wonder why they put this way in their book? It did nothing,
Thanks DelSolSweetie for setting me straight..........
