Ksol Posted June 13, 2010 Share Posted June 13, 2010 Rocco is trying to convince me to go B-20 and build the shiot out of it as well. That's not a bad suggestion. It's a fairly cheap motor, it's only downfall is it doesn't have v-tec but if you built it, I'm sure that wouldn't matter. You could bore out a B18C1 to 2.0 liters and have the best of both worlds. Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 13, 2010 Author Share Posted June 13, 2010 That's not a bad suggestion. It's a fairly cheap motor, it's only downfall is it doesn't have v-tec but if you built it, I'm sure that wouldn't matter. You could bore out a B18C1 to 2.0 liters and have the best of both worlds. If I go B-20 it will most likely be a turbo build, so not too worried about Vtec! Link to comment Share on other sites More sharing options...
Ksol Posted June 13, 2010 Share Posted June 13, 2010 If I go B-20 it will most likely be a turbo build, so not too worried about Vtec! Is the compression ratio on a B20 good for boost or do you intend on changing that with the internals? Any time line for this full build? two years maybe? You definitely should have upgraded to the PasswordJdm strut bad for the extra $30 or so dollars. I looked up what it was worth these days after talking to you the other day. Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 13, 2010 Author Share Posted June 13, 2010 Is the compression ratio on a B20 good for boost or do you intend on changing that with the internals? Any time line for this full build? two years maybe? You definitely should have upgraded to the PasswordJdm strut bad for the extra $30 or so dollars. I looked up what it was worth these days after talking to you the other day. I like what I got. Besides I am getting as good of deals as I can so I can do budget build, and get everything done at once. B20 build will be complete rebuild, or any motor I do for that matter. Link to comment Share on other sites More sharing options...
Ben. Posted June 13, 2010 Share Posted June 13, 2010 B20 cylinder walls are sooooo thin. You could always sleeve it but.. still there's always that risk. They do rock some low compression from the factory though. And you can retain A/C as well. Link to comment Share on other sites More sharing options...
michaelnguyen Posted June 13, 2010 Share Posted June 13, 2010 Hey im liking it, wish you luck on the build! btw what ever happened to your first sol? could you tell me what kind of engine is in your samba? Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 13, 2010 Author Share Posted June 13, 2010 Hey im liking it, wish you luck on the build! btw what ever happened to your first sol? could you tell me what kind of engine is in your samba? Same engine in all 3 Sol's. D16Z6 SOHC vtec. Sold first Samba Sol for $6500 because we needed to pay off a couple bills, and put a tranny in wife's Toreass! Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 14, 2010 Share Posted June 14, 2010 yeah a b20 is no bueno. like ben said, the cylinder walls are too thing. you could always to a stroker h22 or a small h22turbo at 8psi. but if you want to retain ac....b16? gsr? Link to comment Share on other sites More sharing options...
Ben. Posted June 14, 2010 Share Posted June 14, 2010 You can keep the A/C with any b-series setup in a del sol unless you've got an FUBAR turbo manifold or something is in the way. Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 14, 2010 Author Share Posted June 14, 2010 I am miles away from any kind of swap, and believe me a lot of research will be done. I was already discounting the B-20 because O prefer not to have to sleeve the block. Link to comment Share on other sites More sharing options...
OTiS Posted June 14, 2010 Share Posted June 14, 2010 i wouldent go with the pwjdm strut bars. imho they are overpriced cheaply made replicas. you can buy the real part usually cheaper. pearce why not try a k20??? im becoming fond of the kseries motors. they can handle like 41psi of boost on stock internals i think. could be wrong so if i am someone correct me. got your wheels yet? Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 14, 2010 Share Posted June 14, 2010 41 psi? i call bs i hope you meant 14 Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 14, 2010 Author Share Posted June 14, 2010 i wouldent go with the pwjdm strut bars. imho they are overpriced cheaply made replicas. you can buy the real part usually cheaper. pearce why not try a k20??? im becoming fond of the kseries motors. they can handle like 41psi of boost on stock internals i think. could be wrong so if i am someone correct me. got your wheels yet? Wheels are on look back in post! Link to comment Share on other sites More sharing options...
OTiS Posted June 14, 2010 Share Posted June 14, 2010 41 psi? i call bs i hope you meant 14 i couldent find the video i originally saw it on but heres some k20 vids Link to comment Share on other sites More sharing options...
OTiS Posted June 14, 2010 Share Posted June 14, 2010 ahh looks good. that was a nice pile of stuff. makes me miss my honda even more Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 14, 2010 Share Posted June 14, 2010 ive seen both vids. the second vid doesnt even say anything about being boosted. Link to comment Share on other sites More sharing options...
93d3ls0l Posted June 14, 2010 Share Posted June 14, 2010 ive seen both vids. the second vid doesnt even say anything about being boosted. thats because the hatch in the second vid is N/A and isnt boosted . the only thing in the second video with boost is the supra . mike i want your sol now damnit. i give you 1 dollah Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 20, 2010 Author Share Posted June 20, 2010 Well I did a couple things! Stole front lip off of my $500 EX Civic! Installed new OEM mud guards! Here is the difference the gel makes for David, and some one else! Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 20, 2010 Share Posted June 20, 2010 Nice mike lol. Btw I can't see the comment u left for me. I'm on an itouch Link to comment Share on other sites More sharing options...
tallhamer88 Posted June 21, 2010 Share Posted June 21, 2010 looks good Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 21, 2010 Author Share Posted June 21, 2010 Thanks! Next pics will be of it lowered, if I bother to post them up. Link to comment Share on other sites More sharing options...
Ben. Posted June 21, 2010 Share Posted June 21, 2010 Thank God you're lowering it.. Looks haggard. Even my overweight Legend on 18's sits lower than that..LAWL. Link to comment Share on other sites More sharing options...
airjordan223 Posted June 21, 2010 Share Posted June 21, 2010 Looks good Michaelangelo Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 21, 2010 Author Share Posted June 21, 2010 Looks good Michaelangelo Thanks man! Does anyone have measurements for the stock height on Sol?? This one is slightly lowered on Egay sleeves right now. So I want to know what it will go down to from where it is at now?? Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 23, 2010 Share Posted June 23, 2010 POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST POST Link to comment Share on other sites More sharing options...
