mpearce1974 Posted June 9, 2010 Author Share Posted June 9, 2010 Yeah I was wondering too, i really need to clean mine. Please fogive the shiitty cut and paste job! This is the line of products I use, give them your contact info. and they will have local rep\seller get ahold of you! http://www.prowax.com/index.shtml This is the degreaser I use mixed 1 to 1 with water. They sell spray bottles! http://www.prowax.com/degreaser.shtml Red Devil degreaser FTW! Pretty safe on paint, never had any problems, slightly irritating to hands, but not too bad. Usually just spray on let set on slightly warm engine and I also hit every thing under hood with it, cleans plastics, and res. bottles really well! Then just spray off with hot hater at carwash. This is what I use for the paint underhood, and in door jams. http://www.prowax.com/wheel_tire.shtml WHITEWALL CLEANER CONCENTRATE 6th one down from top. Be carefull with this!! Youi dont want to get it on the exterior paint, if oxidized it will streak it! Wet fenders and bumper! I use a brush and spray it and brush it at the same time! Try not to let dry! It will remove 15 years of build up amazingly easy! Also I use it for the door jams, and use a wheel cleaning brush to get into hard to reach areas. Then of course spray off with high pressure rinse! For the primer under hood try this! The top one! http://www.prowax.com/clay.shtml If you want to knowe about their waxes and cutters let me know! Hope this helps! Awesome! Thanks! I'll be sure to try this. I need to put my new valve cover on too so my engine will look Ballin'. If this stuff makes it look like brand new, i'm going to cry. I forgot the stuff that makes it shine! It is just sprayed on, then leave it alone, will dry nice and uniform as long as you coat everything well! Also this breaks down 1 to 1 with water! I also use this on all plastic and vynl interior! Can be sprayed on tires and left alone also, has a flat clean look to it, but not glossy, and will not last too long! http://www.prowax.co...waterbase.shtml 7th one down Premo! If you want high gloss and lasting try this on tires only!!!!! It is solvent based! http://www.prowax.co...s_solvent.shtml 2nd one down Blue Gloss! Also if you have any faded moldings, bumpers, ect! Use this shiot! http://www.prowax.co...waterbase.shtml 2nd one down Blue Ice is the shiot! Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 11, 2010 Author Share Posted June 11, 2010 Well got a few things in, rims no here til tomorrow! Benen Strut bar installed, though it will have to come right off, but I dont care! Link to comment Share on other sites More sharing options...
Xeryon Posted June 11, 2010 Share Posted June 11, 2010 oooo, nice pile o' stuff. those rear trailing arm main bushings are a pita though, had to torch my set out. Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 11, 2010 Share Posted June 11, 2010 we had to do the same ont he EF. does that just happen with all trailing arm bushings? Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 11, 2010 Author Share Posted June 11, 2010 we had to do the same ont he EF. does that just happen with all trailing arm bushings? Any Honda with about 80K miles needs them. I has 12 ton press so I am going to try that route first. Last time I had no press and cut mine out with a jig saw with a knife type blade in it. Link to comment Share on other sites More sharing options...
Xeryon Posted June 11, 2010 Share Posted June 11, 2010 They usually have to be cut out. i think the originals must have used a special machine to install them as they have four wings that stick out into grooves in the wall of the bushing housing. Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 11, 2010 Share Posted June 11, 2010 ewwwww. im liking that strut bar though. very nice what springs did you get? Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 11, 2010 Author Share Posted June 11, 2010 ewwwww. im liking that strut bar though. very nice what springs did you get? I went with my Ksports. Lowered down to $126.00 and you can make a best offer too! I bet you can get for $115.00 shipped! Springs Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 11, 2010 Share Posted June 11, 2010 ill keep those bookmarked. cause ill be getting tokico blues for sure lol. just couldnt decide what springs to go with. are you still required to run th etwo silver plates on each side of the spring? or do you use your oem ones? Link to comment Share on other sites More sharing options...
tallhamer88 Posted June 11, 2010 Share Posted June 11, 2010 ill keep those bookmarked. cause ill be getting tokico blues for sure lol. just couldnt decide what springs to go with. are you still required to run th etwo silver plates on each side of the spring? or do you use your oem ones? i took the oem ones off. and put them on new ones. Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 11, 2010 Author Share Posted June 11, 2010 Well got a few things in, rims no here til tomorrow! Benen Strut bar installed, though it will have to come right off, but I dont care! New rims are here, but due to slight altercation with tire shop not going on til tomorrow at noon! Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 12, 2010 Share Posted June 12, 2010 very nice. gonna match the samba perfectly Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 12, 2010 Author Share Posted June 12, 2010 Just quick pics! Link to comment Share on other sites More sharing options...
Orca89 Posted June 12, 2010 Share Posted June 12, 2010 *drools* haha. didn't much care for the rims solo, but dang they look good on the Samba... Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 12, 2010 Author Share Posted June 12, 2010 Wait til I tint windows, and paint it a shade or 2 darker! Link to comment Share on other sites More sharing options...
Ben. Posted June 13, 2010 Share Posted June 13, 2010 Did you smoke your headlights or did they come that way? I wouldn't mind something similar on mine..especially in one piece form.. D= Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 13, 2010 Author Share Posted June 13, 2010 Did you smoke your headlights or did they come that way? I wouldn't mind something similar on mine..especially in one piece form.. D= Lens are not tinted, just housings are black. Link to comment Share on other sites More sharing options...
Ben. Posted June 13, 2010 Share Posted June 13, 2010 Ohhhhhhhh, gotcha. Are you trying to build a clone of your original Samba Sol? LOL. Looks it. Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 13, 2010 Author Share Posted June 13, 2010 Ohhhhhhhh, gotcha. Are you trying to build a clone of your original Samba Sol? LOL. Looks it. Some what of a clone, but this one is going all out. Looking to swapp at some point, but its all about interior, suspension, and then autobody and paint. Then its turboed LS Vtec, or something else, perhaps something more exotic?? Link to comment Share on other sites More sharing options...
Ben. Posted June 13, 2010 Share Posted June 13, 2010 Indeed. H2B if you don't mind a lack of A/C.. Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 13, 2010 Author Share Posted June 13, 2010 Indeed. H2B if you don't mind a lack of A/C.. Once I can not have it be my DD I will consider ridding myself of AC, but til then it stays. Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 13, 2010 Share Posted June 13, 2010 dont do lsv. not very reliable. ask sarah about that lol Link to comment Share on other sites More sharing options...
shak3yb0n3z Posted June 13, 2010 Share Posted June 13, 2010 lookin sexy! Link to comment Share on other sites More sharing options...
Ksol Posted June 13, 2010 Share Posted June 13, 2010 Some what of a clone, but this one is going all out. Looking to swapp at some point, but its all about interior, suspension, and then autobody and paint. Then its turboed LS Vtec, or something else, perhaps something more exotic?? Ls-vtec is nice but I think you need a k-motor and you know it. Reliable and still fast enough to get you around. Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 13, 2010 Author Share Posted June 13, 2010 Ls-vtec is nice but I think you need a k-motor and you know it. Reliable and still fast enough to get you around. Rocco is trying to convince me to go B-20 and build the shiot out of it as well. Link to comment Share on other sites More sharing options...
