ATF Posted April 27, 2010 Share Posted April 27, 2010 Hello, My left turn signal is blinking twice as fast as normal. (front & back) was wondering what causes this or if it has ever happened to anyone. thanks Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted April 27, 2010 Share Posted April 27, 2010 either you have a blown bulb or the fuse is blow. both are cheap and a quick fix Quote Link to comment Share on other sites More sharing options...
parajeeper Posted April 28, 2010 Share Posted April 28, 2010 So true, just happened to me. If that happens to both turn signals and fuses/bulbs are good then your flasher relay has gone bad. My Civic is 15 years old and using the original, so not a common problem. Quote Link to comment Share on other sites More sharing options...
hiemsnox Posted April 29, 2010 Share Posted April 29, 2010 you guys are lucky lol, my problem is that none of the lights flash the relay makes noise of clicking like it should... but somewhere along the lines i think i lost a ground cause i still cant figure out where its coming from. Quote Link to comment Share on other sites More sharing options...
