idle problems
brody87
I am having a problem with idling car jumps up and down in rpmsfrom around 1-2thousand also when the car gets hot it will not start after drivig it for so long but will start again some time later any help would be appreciated!
  • 1 month later...
make sure your coolant is full... if its empty it will cause the car to idle up and down. could be your iac sensor as well. try those and see if it fixes it.
  • 3 months later...
My idle problem was the FIT Valve. Popped the cover off, and it had completely backed all the way out, just screwed it back in all the way, idle surge was fixed.
