Asthesunsetsxe Posted April 23, 2010 Share Posted April 23, 2010 Hello. I have a 1996 Honda civic 1.6 vtec with an auto trans. Yesterday I noticed a lack of power and that instead of my vtec engaging there would be a loud clicking/clunking noise very rapid. When I let off the gas it would stop. Eventually as I drove home the noise got progressivly worse until I actually pulled off the road because I was worried for my car. The noise now is anytime I touch the gas pedal. About a week ago my alarm system stopped working, not sure if the two are related by any means. My car is sitting on the side of the road, I'm going to tow it today and try to figure it out, any ideas? Quote Link to comment Share on other sites More sharing options...
Turtlehead Posted April 23, 2010 Share Posted April 23, 2010 First thing, when do you think the vtec should engage? Secondly, I would start by seeing if the timing is correct. There is a chance that it jumped a tooth on the timing belt. I would certainly be looking of an ignition timing issue since it is a probable cause and costs nothing but time to diagnos. Third, it sounds like you may have a bad low end bearing (a.k.a. either a rebuild or replace the engine). Play around with it and see what you find. Quote Link to comment Share on other sites More sharing options...
Asthesunsetsxe Posted April 23, 2010 Author Share Posted April 23, 2010 Okay. Well it first started only at high rpm. Then about an hour later was throught low to high rpm it all happened. My friends are on their way and we are going to go take a look at it in the parking lot. Quote Link to comment Share on other sites More sharing options...
Asthesunsetsxe Posted April 24, 2010 Author Share Posted April 24, 2010 So it's isn't the timing. I checked and there is no oil. I added 3 quarts and now the tapping has gotten more quiet but is still there. The tapping is completely uniform and I cannot tell where it is coming from although it's definitly from the engine. I recently checked the oil about a month prior and it was of normal level. After adding oil an starting the car, I checked the oil and it was Black, almost silver. Any ideas? Quote Link to comment Share on other sites More sharing options...
Xeryon Posted April 25, 2010 Share Posted April 25, 2010 Tapping might be a rod knock. At the very least is would be the valves. If it is the valves just ignore it, many hondas do it. You could take the time to adjust the valve lash and correct it if you wanted and it would quiet down. if it is the rod just keep driving it till it blows and replace the engine. Quote Link to comment Share on other sites More sharing options...
Asthesunsetsxe Posted April 26, 2010 Author Share Posted April 26, 2010 But if it blows then wouldn't it trash my head as well? As it sits the head is good and I'd only have to replace the bottom end. Quote Link to comment Share on other sites More sharing options...
Xeryon Posted April 27, 2010 Share Posted April 27, 2010 Why bother when you can get an entire engine, trans head and block for a few hundred? Quote Link to comment Share on other sites More sharing options...
Turtlehead Posted April 30, 2010 Share Posted April 30, 2010 Why bother when you can get an entire engine, trans head and block for a few hundred? ^ Agreed. Quote Link to comment Share on other sites More sharing options...
