s_frost Posted April 12, 2010 Share Posted April 12, 2010 96 accord, 4 cylinder auto, 162k miles A few months ago, before I faced a slew of repairs, I never noticed anything unusual about how my car was shifting. After all these repairs (and I don't know how they would have affecting anything...), I realize that my accord shifts rough when driving. It shifts at the right times and all that, but the jerk is distinguishable. Plus, when I keep my foot on the brakes and switch between the gears, it also shifts rough, especially from anything to reverse, which actually makes a loud click. Is something wrong with my transmission? If I didn't have a leaking rear main seal and a timing belt due in the next 10k miles, I wouldn't care about some rough shifting, but I've had this thing less than a year and already had to put a few thousand into it, so I'm suspicious that I should get out from under it while I can... Quote Link to comment Share on other sites More sharing options...
CleanGSR Posted April 12, 2010 Share Posted April 12, 2010 96 accord, 4 cylinder auto, 162k miles A few months ago, before I faced a slew of repairs, I never noticed anything unusual about how my car was shifting. After all these repairs (and I don't know how they would have affecting anything...), I realize that my accord shifts rough when driving. It shifts at the right times and all that, but the jerk is distinguishable. Plus, when I keep my foot on the brakes and switch between the gears, it also shifts rough, especially from anything to reverse, which actually makes a loud click. Is something wrong with my transmission? If I didn't have a leaking rear main seal and a timing belt due in the next 10k miles, I wouldn't care about some rough shifting, but I've had this thing less than a year and already had to put a few thousand into it, so I'm suspicious that I should get out from under it while I can... Most likely it is unrelated to the other stuff you had done and most likely it is nothing major. This is a common issue with this gen accord's auto tranny's my 97 lx 4cyl did that and my current 96 EX V6 did that when I got it. All you really need to do is a series of tranny fluid changes. Get Honda ATF-Z1 fluid (you'll probably end up needing about 9 quarts total). Drain it (make sure car is lowered back level when draining to get the most fluid out), then refill...this is usually about 3 quarts. Then drive the car for about 500 miles, drain and refill. Drive another 500 or so miles, drain and refill a third and final time. You will notice an improvement the first time. You should notice a big change after the second change. You might not notice it as much the third time, but still important to do. Side Note: Never have yo0ur transmission flushed. All you want to do is normal drain and refills. Flushing a honda tranny can cause problems and stir crap up that is currently trapped in the filter inside. Give it a try...hope it helps. Quote Link to comment Share on other sites More sharing options...
s_frost Posted April 12, 2010 Author Share Posted April 12, 2010 Most likely it is unrelated to the other stuff you had done and most likely it is nothing major. This is a common issue with this gen accord's auto tranny's my 97 lx 4cyl did that and my current 96 EX V6 did that when I got it. All you really need to do is a series of tranny fluid changes. Get Honda ATF-Z1 fluid (you'll probably end up needing about 9 quarts total). Drain it (make sure car is lowered back level when draining to get the most fluid out), then refill...this is usually about 3 quarts. Then drive the car for about 500 miles, drain and refill. Drive another 500 or so miles, drain and refill a third and final time. You will notice an improvement the first time. You should notice a big change after the second change. You might not notice it as much the third time, but still important to do. Side Note: Never have yo0ur transmission flushed. All you want to do is normal drain and refills. Flushing a honda tranny can cause problems and stir crap up that is currently trapped in the filter inside. Give it a try...hope it helps. That...is fantastic. people at the shop have said the transmission is fine, but I've been screwed by various places too many times to outright trust them, and I keep reading that rough shifting of the gears at a stop spells trouble. But if that's normal and can be eased with honda trans fluid, that is a very good thing. Thanks for the info. I'll try to get to it before too long Quote Link to comment Share on other sites More sharing options...
CleanGSR Posted April 12, 2010 Share Posted April 12, 2010 That...is fantastic. people at the shop have said the transmission is fine, but I've been screwed by various places too many times to outright trust them, and I keep reading that rough shifting of the gears at a stop spells trouble. But if that's normal and can be eased with honda trans fluid, that is a very good thing. Thanks for the info. I'll try to get to it before too long No problem. Post back with results if it helps. Like I said, both accords I have had shifted hard and the 2-3 tranny change fixed it both times. Good luck. Quote Link to comment Share on other sites More sharing options...
James Matteu Posted April 12, 2010 Share Posted April 12, 2010 Is your speedometer working? you didn't mention it, but I thought I would ask. And, does the D4 light flash when the transmission is shifting rough? Quote Link to comment Share on other sites More sharing options...
s_frost Posted April 13, 2010 Author Share Posted April 13, 2010 Is your speedometer working? you didn't mention it, but I thought I would ask. And, does the D4 light flash when the transmission is shifting rough? yeah, speedometer hasn't given me any problems. no lights flash, at least I certainly haven't noticed them flashing... Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted April 13, 2010 Share Posted April 13, 2010 No problem. Post back with results if it helps. Like I said, both accords I have had shifted hard and the 2-3 tranny change fixed it both times. Good luck. WTF?? A Nate sighting??? Quote Link to comment Share on other sites More sharing options...
