mitchmedic Posted April 9, 2010 Share Posted April 9, 2010 A few months ago my 1995 Honda civic cx 1.5L started to overheat i have done a few things i thought would help with the problem.. i have replaced the thermostat (all this started to happen right after i replaced the thermostat the first time, i have tried 3 other thermostats since), ect switch or whatever its called, and i have checked both the hoses from the radiator and flushed the radiator, im assuming its a blown head gasket because their is oil in the 2nd to right spark plug and it is puffing out white smoke from the muffler, i haven't replaced the gasket yet because my girlfriends dad says thats its not the head gasket, but im not sure..... can anyone please help me??? thanks ,MitchMedic Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted April 9, 2010 Share Posted April 9, 2010 pull your dipstick..... do you have coolant mixing with coolant? check the rad/overflow.. is their oil in there? normally is there is white smoke.. its coolant burning Is there any fluid coming out out of the tail pipe too? normally if its bad enough you'll see water coming out also look in your overflow.. there should be bubbles coming into it if the HG is broke I wouldnt recomment driving it either.. your either going to throw a rod or something from driving with coolant in the oil or going to warp your head from overheating Quote Link to comment Share on other sites More sharing options...
mitchmedic Posted April 10, 2010 Author Share Posted April 10, 2010 How can I tell if the coolant is mixing? And their is a little water coming out the tail pipe It looked like the water in the overflow was boiling is that bad? And if I don't drive it how will I find out that its fixed or not? Quote Link to comment Share on other sites More sharing options...
s_frost Posted April 15, 2010 Share Posted April 15, 2010 (edited) How can I tell if the coolant is mixing? And their is a little water coming out the tail pipe It looked like the water in the overflow was boiling is that bad? And if I don't drive it how will I find out that its fixed or not? What you've described in this topic sounds about like everything I've ever heard about a bad head gasket. Give the cylinders a compression test if you want to be absolutely sure Edited April 15, 2010 by s_frost Quote Link to comment Share on other sites More sharing options...
OTiS Posted April 15, 2010 Share Posted April 15, 2010 its most likely the headgasket. you can get a full topend gasket kit off ebay for 35ish Quote Link to comment Share on other sites More sharing options...
