EDDIE Z Posted September 7, 2010 Author Share Posted September 7, 2010 I'm interested in painting my valve cover. I know what paint and everything I need. My question is can I just slap it back on or does it need a certain amount of pressure to bolt back on. I also know I need new gasket after removing to paint. And is it safe to leave the motor withought the cover for awhile? Looked around on honda-tech can't rly find the answer all I can find is how to properly paint the cover. Link to comment Share on other sites More sharing options...
Xeryon Posted September 7, 2010 Share Posted September 7, 2010 You can reuse the VC gasket as long as it is in good condition. I am sure there are specific torque settings for a VC, but that assembly is not a high pressure location. Snug tightened would be sufficient. Hell, my car had one of the spark plug wires under the VC and through the gasket for years when I bought it. I didn't even have to replace the cable or the gasket. Just cleaned it off and worked fine. As for leaving it open, the day or so it would be exposed isn't going to hurt much. You could rest another VC over the motor if you have a second one sitting around. If it were me I would just drape an oil rag over it or use a plastic garbage bag to keep dust or moisture out. Link to comment Share on other sites More sharing options...
EDDIE Z Posted September 7, 2010 Author Share Posted September 7, 2010 You can reuse the VC gasket as long as it is in good condition. I am sure there are specific torque settings for a VC, but that assembly is not a high pressure location. Snug tightened would be sufficient. Hell, my car had one of the spark plug wires under the VC and through the gasket for years when I bought it. I didn't even have to replace the cable or the gasket. Just cleaned it off and worked fine. As for leaving it open, the day or so it would be exposed isn't going to hurt much. You could rest another VC over the motor if you have a second one sitting around. If it were me I would just drape an oil rag over it or use a plastic garbage bag to keep dust or moisture out. Thnx all good advice so no specific torque when putting the VC back on just nice and tight? I'll prob replace the gasket to be safe. Link to comment Share on other sites More sharing options...
airjordan223 Posted September 8, 2010 Share Posted September 8, 2010 i think the haynes manual says about 84. So roughly what you put your wheel lugs at. Link to comment Share on other sites More sharing options...
EDDIE Z Posted September 8, 2010 Author Share Posted September 8, 2010 Thnx guys after I get my coilovers going I'm gonna start painting have a real cool idea hope it comes out good Link to comment Share on other sites More sharing options...
adamEj6 Posted September 8, 2010 Share Posted September 8, 2010 i think the haynes manual says about 84. So roughly what you put your wheel lugs at. lol wut? he is asking about the VC torque specs im sure. its like 8 lbs to torque them at. anything much more, and you will be stripping sh1t. Link to comment Share on other sites More sharing options...
Xeryon Posted September 8, 2010 Share Posted September 8, 2010 Snug, not much more. There are only four little bolts, not much bigger then a 10, maybe an 8mm or so. Link to comment Share on other sites More sharing options...
airjordan223 Posted September 8, 2010 Share Posted September 8, 2010 lol wut? he is asking about the VC torque specs im sure. its like 8 lbs to torque them at. anything much more, and you will be stripping sh1t. haha oh yeah wrong bolts. that wouldve been fun. haynes is like 7.2 i think Link to comment Share on other sites More sharing options...
Humphries Posted September 10, 2010 Share Posted September 10, 2010 You can reuse the VC gasket as long as it is in good condition. I am sure there are specific torque settings for a VC, but that assembly is not a high pressure location. Snug tightened would be sufficient. Hell, my car had one of the spark plug wires under the VC and through the gasket for years when I bought it. I didn't even have to replace the cable or the gasket. Just cleaned it off and worked fine. As for leaving it open, the day or so it would be exposed isn't going to hurt much. You could rest another VC over the motor if you have a second one sitting around. If it were me I would just drape an oil rag over it or use a plastic garbage bag to keep dust or moisture out. I usually do 110 in-lbs on my valve cover I keep a plastic bag over the crankcase when it's open. Dont use a rag, it could leave lint particles in the motor. (not enough to mess anything up, but it's better to be safe) Link to comment Share on other sites More sharing options...
EDDIE Z Posted September 10, 2010 Author Share Posted September 10, 2010 The torque is the same for all civics? Link to comment Share on other sites More sharing options...
Xeryon Posted September 10, 2010 Share Posted September 10, 2010 most civics from about 1985~ish to 2005~ish essentially have the same engine. Link to comment Share on other sites More sharing options...
EDDIE Z Posted September 16, 2010 Author Share Posted September 16, 2010 All good info thnx guys. Anyone have a good write up on installing groundcontrol coilovers? Was looking for some info all I found is installing with tokiko blues or yellows just want GC installation. Any tools I need besides spring compressor any special tools. Link to comment Share on other sites More sharing options...
adamEj6 Posted September 17, 2010 Share Posted September 17, 2010 just sockets and such. Link to comment Share on other sites More sharing options...
EDDIE Z Posted September 17, 2010 Author Share Posted September 17, 2010 Thnx anything I should be worried about when removing and installing? Link to comment Share on other sites More sharing options...
adamEj6 Posted September 19, 2010 Share Posted September 19, 2010 might break a few bolt on the rear lca's. just have some spares in case. Link to comment Share on other sites More sharing options...
OTiS Posted September 19, 2010 Share Posted September 19, 2010 might break a few bolt on the rear lca's. just have some spares in case. iv heard this happens alot tbh. google majestic honda and type in all the info and order some replacements. better to be safe than sorry. Link to comment Share on other sites More sharing options...
EDDIE Z Posted September 19, 2010 Author Share Posted September 19, 2010 Thnx alot guys I'll def look into it. Link to comment Share on other sites More sharing options...
Humphries Posted September 23, 2010 Share Posted September 23, 2010 just ordered all new hardware for my crankcase. saved 200 dollars compared to the dealership prices. Link to comment Share on other sites More sharing options...
EDDIE Z Posted October 7, 2010 Author Share Posted October 7, 2010 Installed fogs heres a few quick pics thinking about getting brighter bulbs though these are pretty weak. Link to comment Share on other sites More sharing options...
airjordan223 Posted October 7, 2010 Share Posted October 7, 2010 MAD TYTE YO! looks good Link to comment Share on other sites More sharing options...
EDDIE Z Posted October 7, 2010 Author Share Posted October 7, 2010 MAD TYTE YO! looks good Thnx man next is spoon duckbill muds and it will be done for the winter. Link to comment Share on other sites More sharing options...
SpeedDemon Posted October 8, 2010 Share Posted October 8, 2010 looks good man. your on the same track im on, i have my mud flaps on, will be getting a CF duckbill with LED third brake light, and fog lights to follow whats next on the list other than that for you? Link to comment Share on other sites More sharing options...
EDDIE Z Posted October 8, 2010 Author Share Posted October 8, 2010 looks good man. your on the same track im on, i have my mud flaps on, will be getting a CF duckbill with LED third brake light, and fog lights to follow whats next on the list other than that for you? Nice I'm not goin for the carbon wing. Didn't know u had flaps till I saw ur rims on haha. I have no choice but to buy new ones bin going to the junk yard none stop can't find any. Well for winter just goin for duckbill flaps and before winter rly hits side markers. That will be all for winter Link to comment Share on other sites More sharing options...
EDDIE Z Posted October 11, 2010 Author Share Posted October 11, 2010 Was at the mall came out and my car window was gone the idiots couldnt figure out how to take my stereo flip out screen just got my ipod and made a mess of my glove box. hope I never catch them Link to comment Share on other sites More sharing options...
Xeryon Posted October 11, 2010 Share Posted October 11, 2010 who goes to a mall? Link to comment Share on other sites More sharing options...
