Honda99Civic Posted February 20, 2010 Share Posted February 20, 2010 Im doing a motor swap into my 99 civic ex just want to make sure i got everything i need.Axles,shift linkage t bracket from a 94-01 integra.And left side motor mount from 99-00 SI.Is there any wiring problems i will run into.Im swapping a ls/vtec with gsr head its OBD2.All info would be really appreacited thanks. Link to comment Share on other sites More sharing options...
Honda99Civic Posted February 21, 2010 Author Share Posted February 21, 2010 Try doing a search before you post. There is a whole section of the forum dedicated to engine swaps... http://www.hondaforums.com/index.php?/forum/7-engine-tuning-upgrades-and-swaps/ You'll most probably find the answers to most of your questions in there! There is a section on the LS swap as well... (Have a look through the stickied threads at the top!). no help there but thanks also i need to know what alternator belts to use should be doing swap on friday so all info will be great THANKS. Link to comment Share on other sites More sharing options...
adamEj6 Posted February 22, 2010 Share Posted February 22, 2010 use gsr belts. sounds like you got everything, get a obd2 p72 ecu and youre good. Link to comment Share on other sites More sharing options...
Honda99Civic Posted February 28, 2010 Author Share Posted February 28, 2010 use gsr belts. sounds like you got everything, get a obd2 p72 ecu and youre good. Please if anybody can tell me everything i need to do the swap i keep getting different answers.I got motor and trans ecu p28 chipped alxes not sure on mounts shift linkage.Also i keep hearing ppl say i need half shaft.Im going with obd2 to obd1 jumper so i can get it tuned.Im to the point now where ill send you a money order for the right info or you could call me at 717 627-0652.THANK'S FOR THE HELP Link to comment Share on other sites More sharing options...
Honda99Civic Posted February 28, 2010 Author Share Posted February 28, 2010 Please if anybody can tell me everything i need to do the swap i keep getting different answers.I got motor and trans ecu p28 chipped alxes not sure on mounts shift linkage.Also i keep hearing ppl say i need half shaft.Im going with obd2 to obd1 jumper so i can get it tuned.Im to the point now where ill send you a money order for the right info or you could call me at 717 627-0652.THANK'S FOR THE HELP Im tired of searching ready to pull my hair out over this and for the guy above i did research just everyone has differnt answers.THANK'S FOR THE INFO AGAIN Link to comment Share on other sites More sharing options...
