need help with mini me
it started by me changing my radiator to a new one. found out i had a crapty headgasket and a pit in the head. now im lookin at doing a mini me but i need help because this is the first time iv done anything like this and i have a few questions. block will be d15b7 and head will be d16z6 i believe. i get get the z6 head and ecu for $100
i bought a headgasket kit for the d15b7. will the headgasket thats in that fit with the d16z6 head?
will i need to change the intake manifold, exhaust manifold, throttle body, fuel rail or fuel injectors?
which distributor do i use?
will the headstuds need to be replaced with the new head?
the ecu ill be getting will be from an auto del sol, will i need a new ecu from a manual transmission z6?
what gaskets need to be replaced for the entire process?
will i need to change the timing belt to a z6 timing belt?
thats all i can think of at the moment but if i remember more later ill ask
You should check HT for a tutorial on this. They already have several with dozens of pictures telling you everything you need to do.
One thing for certain, you will need to have an ecu from a manual and not an auto for this to work right.
all it is is a VTEC head swap everything from the HG up will be on your d15 block with vtec wired up on a p28 ecu
z6 HG
z6 dizzy
z6 timming
z6 p28 ecu
z6 selinode
and still unsure bout the cam gear
z6 HG
z6 dizzy
z6 timming
z6 p28 ecu
z6 selinode
Are you sure about head gasket? Because I am thinking you need HG to match block!!! :dry:
looked at majestic and its sayin that the d15b7 and d16z6 head gasket is the same, and the intake manifold gasket is the same. but i couldent find the intake manifold itself on the website. does anyone know if the intake manifolds are diffrent on d15 and d16s? if not then ill use my d15 inake manifold
already had it bookmarked. it says optional z6 im. so my d15 shuld fit. and the z6 gaskets are the same as the d15 but why does everyone say use the y8 and the y8 spark plugs?
z6 HG
z6 dizzy
z6 timming
z6 p28 ecu
z6 selinode
i have the two bold off my z6 along with the fuel rail/injectors (idk if you would need em too).. sell em cheap cause they are taking up room.. and we have WAY too many car parts laying around
no head though.. i sold both of em.. and i just sold my timing gear
i believe you can use the Z6 gear too.. or just buy an adjustable one
im gettin a d15 head from kegger but ill keep you in mind delsolsweetie. i plan on gettin all the stuff to do a mini me swap fairly soon. im just gettin the d15 head to get my car runnin as quick as possible.
