crxnonvtec Posted October 2, 2009 Share Posted October 2, 2009 s a 91 crx dx with a d16a6 swap, jackson racing supercharger, str cam gear, exhaust....I changed the iacv 3 diff times all were clean and the same result, coolant temp sensor is good, swapped map two times same result, iat tested good, new distributor from cap to shaft, new main relay, new o2....vacuum tested good so did the fuel pressure...it runs great just stays at 2500 it dropped once when I drove it a lil and never did again. and no the throttle cable isnt stuck. also I had swapped the whole intake assembly back to the stock intake with all the components and still at 2500rpm. anyone got suggestions?? NO CODES!!!! Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted October 2, 2009 Share Posted October 2, 2009 what ECU are you using? did you get a good tune? Quote Link to comment Share on other sites More sharing options...
crxnonvtec Posted October 2, 2009 Author Share Posted October 2, 2009 its not high boost its only 5 lbs im not sinking alot of money until it runs right. It idled at 2500rpm also when i switched the intake to the stock one ...As for ecu i have a jet chipped ecu and im running the fmu plus i got two stock ecu that work in other cars. All ecus do the same idles at 2500 no codes Quote Link to comment Share on other sites More sharing options...
cranny Posted October 2, 2009 Share Posted October 2, 2009 you did a vacuum test? what vacuum does it show at idle fully warmed up? sounds like a vacuum problem to me. Quote Link to comment Share on other sites More sharing options...
xxhrdcr4lifexx Posted October 3, 2009 Share Posted October 3, 2009 check the egr prob could be cleaned up a bit, try cleaning the iacv or buy a new 1, usually if there's a vacuum leak itll have a high or a low pulsing idle depending witch vacuum line is leaking. so ya either clean or replace the egr, iacv, and this also just came to mind the throttle sensor could be bad. just a couple idea's for you to try out.... Quote Link to comment Share on other sites More sharing options...
crxnonvtec Posted October 5, 2009 Author Share Posted October 5, 2009 anyone read the body?? it said i cleaned the iacv's and tried 3 diff ones...and the vacuum was dead center in the green...everything vacuum controled also seems to be working well Quote Link to comment Share on other sites More sharing options...
